!!Help needed with connecting an RCVDS 05 to a Barco 708
saseagle
Posted: Sun Feb 17, 2008 10:35 pm    Post subject: !!Help needed with connecting an RCVDS 05 to a Barco 708
I just received an RCVDS 05 to use with my Barco 708 but I am not sure which type of serial cable that I need (Straight through or Null). I read somewhere that you have to be careful as the cable carries 30V and needs to be correct or it could damage both the switch and the projector.
Any help would be much appreciated.
Les
Heywood Jablome
Posted: Sun Feb 17, 2008 10:53 pm    Post subject:
I have not looked at my 708 for some time (its' buried!) but does it even have a Periph 800 port?
saseagle
Posted: Sun Feb 17, 2008 10:58 pm    Post subject:
yes there is a projector connection port on the back alongside the serial in and outs, as far as I am aware this is used to connect to the RCVDS 05 so that the switch can communicate directly with the projector and give access to the addition adjustments i.e. contrast, brightness etc.
Les
saseagle
Posted: Mon Feb 18, 2008 6:09 pm    Post subject:
Hi, problem solved , I eventually got an answer from BARCO. The cable that is used is a normal Male to Female straight through serial cable.
Les
Person99
Posted: Mon Feb 18, 2008 7:11 pm    Post subject: Re: !!Help needed with connecting an RCVDS 05 to a Barco 708
I would not recommend using this. These are pretty noisy switchers. You might want to consider a better option.
saseagle
Posted: Mon Feb 18, 2008 7:35 pm    Post subject:
Hi, Dave do you mean noisy as in the fan noise or do they cause noise in the signal, I have never use one before.
Les
scoobydoo
Posted: Mon Feb 18, 2008 7:38 pm    Post subject:
I have a RCVDS05 and a HD Leeza. I found the leeza is noiser than the 05. though my receiver is noiser than both of them. just turn up the volume and drain it out.
Sort of like when you have funny noises coming from your car engine..turn up that radio. Smile
Person99
Posted: Mon Feb 18, 2008 8:56 pm    Post subject:
Les
video noise. They were really not designed for use in critical viewing.
saseagle
Posted: Mon Feb 18, 2008 10:09 pm    Post subject:
Thanks for the advise Dave, i will try it out and see how it goes and if it causes any problems I will replace it with another type of switch, problem is I know very little about these things and would not know what to looks for. any suggestions?
Les
