Sony D50 memory settings
drice1234
Posted: Sun Feb 17, 2008 3:47 am    Post subject: Sony D50 memory settings
I was having a bit of a problem where the picture size from my upscaling DVD player was a little different from the HD Satellite receiver so I went in and changed the settings and am having a problem. First off both sources are coming in on input B via a receiver. I have setup input 2 for the DVD player and all looks fine. I have hit memory after changing the setting. I then setup memory 7 for the satellite receiver and then hit memory. The problem I am having is that I cannot seem to be able to assign a specific memory to each source. If I go into the menu and pick input 2 then the DVD player looks fine but the satellite picture is off of the screen. If I pick input 7 then the DVD picture is to small on the sides. I have checked out the frequency and each source has a different frequency setting so the PJ should not be confusing the two sources.
Dan
