1080p on Sony G90
gharagozloo
Posted: Sat Feb 16, 2008 5:28 am    Post subject: 1080p on Sony G90
Hello All;
I just purchased a brand new G90. It is great. However when I connect a Blu-ray with an HD Fury to the projector I can only get a good image at 720p. 1080i and 1080p are dark and show a lot of horizontal movement. Please help! Thanks
Farid
farid
Posted: Sat Feb 16, 2008 2:34 pm    Post subject:
Check your sync settings.
Posted: Sat Feb 16, 2008 2:56 pm    Post subject:
Farid, how exactly is everything cabled up, and do you have the power supply for the HD Fury?
More specifically, how much analog cable do you have between the HD Fury and the projector?
gharagozloo
Posted: Sat Feb 16, 2008 3:10 pm    Post subject:
Bluray - 2foot cable - HD Fury with power - 6 inch RGB (HDFURY) RGB cable.
thanks
farid
Posted: Sat Feb 16, 2008 3:22 pm    Post subject:
Is your clamp set to HC?
gharagozloo
Posted: Sat Feb 16, 2008 6:09 pm    Post subject:
You guys are just great!
Very Happy
I made the following cahnges in the Prouser Menu:
Clamp: HP
V Shift: Wide
Sync rate: Auto
UL: Wide
The Blu-ray at 1080p and HDDVD at 1080p/24 LOOK FABULOUS.
Thanks again.
Farid
farid
