Cinemateq and best connection
Hulio
Posted: Wed Feb 13, 2008 10:49 am    Post subject: Cinemateq and best connection
Right now i'm enjoying a 1080i picture from my PS3 (only bluray) trough HDFury on port 3 of a BG 808.Nice picture quality, only downside is the well known picture shift to the left.Playing with phase, raster shift and horizontal width did the trick a bit, still not 100%.
Because i already own a scaler (Cinemateq Picture Optimizer Plus II-SDI) for my SD-DVD collection, i want to use it with my PS3 in order to be able to change the porch settings.The problem is, i'm a little bit lost regarding the best connection and i can beter ask your advice before buying an RTC 2200, yet to come TC1500 or whatever.
Cinemateq inputs:
2x SDI
2x component
2x scart
2x S-video
2x composite
Cinemateq outputs:
1x DVI-D
1x component
1x RGB (5xBNC)
1x VGA
There are also 2x bypass inputs:
5x BNC-will bypass only to 5xBNC out
VGA-will bypass only to VGA out.
What you guys will do in my situation ?
Thanks in advance.
Stan
kschmit2
Posted: Wed Feb 13, 2008 12:15 pm    Post subject:
here's a link to the brochure:
http://www.curtpalme.com/forum/files/picture_optimizer_plus_ii_sdi_117.pdf
The POPIISDI is not even capable of processing HD inputs.
Iirc only the POPHD has that functionality http://www.curtpalme.com/forum/files/picture_optimizer_plus_hd_sdi_183.pdf
Kai
Picture Optimizer Plus HD (SDI).pdf
Cinemateq Picture Optimizer Plus HD (SDI) brochure
 Filename:  Picture Optimizer Plus HD (SDI).pdf
 Filesize:  149.22 KB
 Downloaded:  575 Time(s)
Picture Optimizer Plus II SDI.pdf
Cinemateq Picture Optimizer Plus II SDI brochure
 Filename:  Picture Optimizer Plus II SDI.pdf
 Filesize:  104.49 KB
 Downloaded:  678 Time(s)
Hulio
Posted: Wed Feb 13, 2008 10:21 pm    Post subject:
Allright, thanks for the input.
Trying this: PS3-->HDMI to DVI cable-->HDFury blue edition-->Cinemateq bypass input(5x BNC)-->Cinemateq bypass output(5x BNC)-->RGBHV cable-->Barco port 5, will give me a beter picture then HDFury straight into port 3 ?
kschmit2
Posted: Wed Feb 13, 2008 11:14 pm    Post subject:
That's a question of Port 5 vs. Port 3.
Kal might know which is better.
