Help! about NEC 6100G
iloveu
Posted: Tue Feb 12, 2008 7:55 pm    Post subject: Help! about NEC 6100G
I have read NEC PG Series/Mechanical Setup Procedure,and done step by step.
Eeverything is OK,but I can't get "IMAGE CENTERING"[center the IMAGE inside the RASTER], even if I adjust SHIFT to Max Value:100.
What can I do?
Help!!!
Thanks.
ps:
Source signal is HD Player with HDMI, and convert HDMI to RGB by HDfury.
Brooklyn
Posted: Tue Feb 12, 2008 7:58 pm    Post subject:
oops nevermind.
Elaine Benes
Posted: Tue Feb 12, 2008 7:59 pm    Post subject:
Return your image centering values to null, then loosen the tube fixing screws, and the slotted rods, toe in the red and blue tubes to overlay green at the center EXACTLY.
Or do you mean the image from your source can't be centered in the raster ? If that is the case, its an issue with your source...If its a computer, change the porches till its centered. If its not a computer, and you don't have enough image shift in the projector to center it in the raster, you'll need an Extron or some other brand of signal processing device which includes H-Shift.
