6PG system board in a 10PG
benareeno
Posted: Tue Feb 12, 2008 5:38 pm    Post subject: 6PG system board in a 10PG
Not sure if this is really an issue..but I put a 6PG system board in my 10PG and when I went to a higher res I got a screen prompt telling me I'm exceeding the bandwidth or something like that.
I was of the opinion that the boards are identical except for one or two parts...is there a part exchange I can do with the old board that would allow the projector to think it's a 9 again?
Brooklyn
Posted: Tue Feb 12, 2008 7:51 pm    Post subject:
From what I've read, all of the PG series system boards are different between the 6s and 9s and the regular, plus and extra. Each board can be used in only each model.
benareeno
Posted: Tue Feb 12, 2008 7:54 pm    Post subject:
I can use a 6 in a 9, as long as it's not a plus or xtra...which it's not.
Elaine Benes
Posted: Tue Feb 12, 2008 7:56 pm    Post subject:
Why don't you just use the 10PG's original system board in it ? Or is it bad ?
dbaisey
Posted: Tue Feb 12, 2008 10:28 pm    Post subject:
Ben,
You may have issues using the 6 in the 10PG. Have you swapped the 1E7's into the donor board? Doug
What H freq are you trying to run? What is it actually saying on screen?
benareeno
Posted: Wed Feb 13, 2008 5:10 am    Post subject:
I'll check what the error is, and yes, it appears that I did have to swap in a system board in order for everything to work properly on this 10PG. What an image though...it has a dimensionality that I've never seen before on any other crt.
Doug, thanks for the tip...I will do this shortly and report back!
Ben
