Marquee Arcing all over the place
SweetChuck
Posted: Mon Feb 11, 2008 12:56 pm    Post subject: Marquee Arcing all over the place
This is very confusing , if I put the HV splitter where its suppose to go and screw the case and everything back together , I get wicked arcing so bad it screws up the picture . The only way to stop it is to unscrew the HV block and let it hang down and the arcing goes away . I have tried cleaning the plugs , checked for dirty connectors in the block and all seems good . It only does it when I screw the block back onto the plastic tube housing . Could I have a leaking HV block ?? Confused
If your there Gino , I believe you had problems with this arcing and soldered a new tip on the lead from the HV supply . I don't believe this is the problem , I have resoldered that tip twice now , very carefuly .
Posted: Mon Feb 11, 2008 1:11 pm    Post subject:
Yes, it's very possible for a splitter to have leakage. To test, grab it with one hand, hold the chassis with the other, have a friend turn the set on.....Wink
NO, DON'T DO THAT!
I've got lots of spares though if you want one.
SweetChuck
Posted: Mon Feb 11, 2008 1:19 pm    Post subject:
NO, DON'T DO THAT!
I just tried that , it made me feel all warm and tingly Shocked
I guess I should should grab one off you then , I can't think of anything else it could be .
Posted: Mon Feb 11, 2008 11:35 pm    Post subject:
Curt undoubtedly has extra HV blocks. Get one from him.
CJ
SweetChuck
Posted: Mon Feb 11, 2008 11:41 pm    Post subject:
Does this look normal ?? see the 3 marks on the back of it . If it where leaking I thought i would see a crack or something , is this a common thing for marquees ?
I'll also get some 246 CPC magnets from you too Curt
Posted: Mon Feb 11, 2008 11:52 pm    Post subject:
Got everything in stock, shoot me an email. If there are any black marks on the block that aren't dust, that's a bad thing. You're dealing with 34Kv here, stuff that can arc over 2" of air, so you don't need a crack to get massive arcing. It's relatively rare for the splitters to fail, but it does happen.
J Kildare
Posted: Wed Feb 13, 2008 1:38 am    Post subject:
Looks toast to me.
HV can arc from a pin hole, and like curt said at least 2" at this voltage.
Jim
Gino
Posted: Thu Feb 14, 2008 1:39 am    Post subject: Re: Marquee Arcing all over the place
I tried resoldering the tips based on Tim's advice. Thought I had sh*t soldering skills so I just wrapped the HV splitter and left it sitting there...
SweetChuck
Posted: Thu Feb 14, 2008 1:46 am    Post subject: Re: Marquee Arcing all over the place
Nah not the soldering , It would be pretty hard to stuff that up . Are you overseas Gino ?
CRT_Ben
Posted: Thu Feb 14, 2008 1:54 am    Post subject: Re: Marquee Arcing all over the place
Gino, your skill with a dentist's drill and you can't solder? Neutral
Joust
TV/Projector: Marquee 8501LC
Posted: Thu Feb 14, 2008 2:00 am    Post subject:
he could drill it out and fill it with some conductive epoxy i bet.
Gino
Posted: Thu Feb 14, 2008 3:38 am    Post subject: Re: Marquee Arcing all over the place
Well, that's what I thought because I couldn't stop the arcing.
Gino
Yep, why's that?
CRT_Ben
Posted: Thu Feb 14, 2008 3:45 am    Post subject: Re: Marquee Arcing all over the place
Well HV is a tricky thing...I'm sure you did fine. You're probably better than you think Wink
SweetChuck
Posted: Thu Feb 14, 2008 3:58 am    Post subject: Re: Marquee Arcing all over the place
Gino wrote:
Yep, why's that?
I just wanted to ask a dental question ,I think I'm getting ripped off ,I'll wait till you get back . Very Happy
Gino
Posted: Thu Feb 14, 2008 6:11 am    Post subject:
feel free to shoot me an email mate
