Help please: Should I just walk away. Now diag lights on
the_avguy
Posted: Mon Feb 11, 2008 8:18 am    Post subject: Help please: Should I just walk away. Now diag lights on
For anyone reading along I have run into nothing but problems with my Marquee 8000.
The last problem was the broken lead on the Red.
But I was able to get picture before with the HV lead to the red disconnected.
Now I can't get any picture and the H. Fail V. Fail and Error lights were on.
I found this thread
https://www.curtpalme.com/forum_archived/viewtopic.php@t=7766.html
and tried disconnecting all three cables and now when I power off and back on I get just the H. Fail and V. Fail lights.
I was gonna get a new lead from Curt but now I am wondering if there isn't to much wrong with the set.
Does anyone have any suggestions for the current problem?
Or a recommendation?
working ECP 4100.
marquee still in pieces, just gathering knowledge.
optoma ep729
Posted: Mon Feb 11, 2008 4:53 pm    Post subject:
Hello
When the anode lead arced, it probably hit the nearest thing which is the scan yoke, and may have taken out your horizontal and vertical sweep boards.
the_avguy
Posted: Mon Feb 11, 2008 4:59 pm    Post subject:
That's what I was afraid of.
I can't see anything obvious on the boards but I suppose that isn't surprising.
I don't suppose anyone in Edmonton or surrounding area has spare parts I can try AFTER I fix the lead?
working ECP 4100.
optoma ep729
Posted: Mon Feb 11, 2008 5:26 pm    Post subject:
I've got lots of parts for the 8000, and they're cheap, since I don't get a lot of call for them any more. Send me the HDM, V board, VIM. I'll repair/swap out for $150 max incl shipping.
the_avguy
Posted: Mon Feb 11, 2008 9:54 pm    Post subject:
Hi Curt,
That is a good offer thanks.
I don't have any more spare cash at the moment but as soon as I do I will pack them up and send them to you.
I will send you a pm first to let you know they are on the way.
Will you be able to tell if that is what is causing my problems?
I would hate to do all this and then find out I have something else bad.
I guess I will get the leads from you at the same time so I better start saving my scheckels.
I do have the old HDM board that came with the set and when I swap that one in I get the same errors.
Does that help in the troubleshooting at all?
I also have three more neckboards to try but I think I ruled those out when I disconnected them from the motherboard right?
thanks
working ECP 4100.
optoma ep729
