Ultra and 9500 convergence boards
Chuchuf
Posted: Wed Feb 06, 2008 7:57 pm    Post subject: Ultra and 9500 convergence boards
Does anyone know if the convergence board from a standard Marquee 9500 can be used in an Ultra chassis to temp. replace the Ultra board that is in there??
I have someone in Europe that I believe is having a problem with their Ultra convergence board (B channel is shaking horiz. and vertically). We have narrowed it down to the convergence board in that the problem follew the board when the B & G convergence wires are swapped.
To test this he has a 9500 there that he can take the convergence board from and put it in the Ultra Chassis, and if the shaking stops send me the Ultra convergence board for repair.
Terry
Posted: Wed Feb 06, 2008 8:18 pm    Post subject:
Yup, have at it. There may have been slight changes from a non Ultra to Ultra, but all I saw the differences were was plastic shields so that you can't put the convergence connectors in my one pin off to smoke them..Wink
nuttall_chris
Posted: Wed Feb 06, 2008 8:24 pm    Post subject:
I might be mistaken, but putting a non ultra convergence board in the ultra projector will will result in the loss of some of the "ultra" geometry features. I was having some problems a couple of months ago with my 9500Ultra and was doing some board swaps when I saw this. But I may not be remembering this properly and it may have been the vertical board.
But for trouble shooting purposes it works fine.
Chris.
Chuchuf
Posted: Thu Feb 07, 2008 2:33 pm    Post subject:
Thanks guys, I suspected as much.
Terry
Posted: Thu Feb 07, 2008 2:43 pm    Post subject:
The vertical board used in the Ultra's is the same vertical board used in the 8110, 8500 and 9500's. You just need to make sure it has the double stack fusible resistors that's mentioned in the maintenance thread.
There's no difference in the vertical (VDM) boards..
Posted: Thu Feb 07, 2008 5:07 pm    Post subject:
nuttall_chris wrote:
I might be mistaken, but putting a non ultra convergence board in the ultra projector will will result in the loss of some of the "ultra" geometry features. Chris.
no that's incorrect. The extra geometry features come from the re-designed Focus control Module, which is called the Focus Geometry Module (FGM) on the Ultra's. As mike and Curt pointed out, the only difference in the Ultra VDM and CM is plastic guards and some hand-soldered add-on's.
Chuchuf
Posted: Thu Feb 07, 2008 5:40 pm    Post subject:
That's exactly what I thought but thanks for the confirmation.
Terry
nuttall_chris
Posted: Thu Feb 07, 2008 5:59 pm    Post subject:
I'm going to have to disagree. On my 9500 Ultra if I swap out the "Ultra" version vertical and convergence boards, I loose some of my geometry controls. For sure I loose top and bottom pin.
If I get a chance tonight I will try swapping out those boards and report back.
Chris
nuttall_chris
Posted: Fri Feb 08, 2008 12:47 am    Post subject:
Ok, I had some time to test this out and I was right Smile
The following features do not work with my older (non ultra) convergence and vertical boards in my 9500Ultra;
- top pin
- top keystone
- bottom pin
- bottom keystone
- horizontal bow
- vertical bow
- vertical skew
My Ultra board versions are;
- Vertical 03-263350-01P issue 11
- Convergence 03-270350-01P issue 7 there is also a sticker with 03-262350-01P so I'm not sure which is valid?
My older non ultra boards are;
- Vertical 03-263330-01P (no issue sticker)
- Convergence 03-262330-01P issue 10
I am running V8.0 software and the older boards are full functional in my 8500 so these are not faulty boards.
See pictures;
Chris.
Old Convergence
 Filesize:  370.01 KB
 Viewed:  5836 Time(s)
Old Vertical
 Filesize:  335.43 KB
 Viewed:  5844 Time(s)
Ultra Convergenge
 Filesize:  378.09 KB
 Viewed:  6335 Time(s)
Ultra Vertical Board
 Filesize:  328.7 KB
 Viewed:  5862 Time(s)
tse
Posted: Fri Feb 08, 2008 1:44 am    Post subject:
The small green wires and resistors are what gets the ultra NS geometry signals into the convergence amp.
Attached is part od schematic showing where signal is summed into amplifier.
Scott
 Filesize:  10.44 KB
 Viewed:  7698 Time(s)
Thomas Jefferson
Posted: Fri Feb 08, 2008 8:05 pm    Post subject:
well that is very usefull info. Basically (if i'm reading Scott's post correctly), any non Ultra Convergence board can be made into an Ultra version by simply hand soldering in the few extra components. Thumbs Up
Of course you would still need the FGM, motherboard, backplane, and V4.2U 35 chip to do a complete conversion on a non-Ultra but if you have an Ultra with a bad convergence module this is an easy fix.
