Split a barco 701 for transport < 31kgs (68lbs)
radar
Posted: Tue Feb 05, 2008 11:29 am    Post subject: Split a barco 701 for transport < 31kgs (68lbs)
Hey folks,
Am about to purchase a barco 701 from another state. Am going there for work anyways, so I thought I'd bring it back with me on the plane. Trouble is, the Barco is about 38kgs (84lbs), so I need to get it to around 68lbs to meet the maximum requirement for air transport (as luggage). I was thinking I bring a screwdriver with me and take the barco apart.
What is the quickest bit I can take out of the PJ with as few screws as possible that would weigh approx 16lbs or more? The lense block? The power supply?
Thanks!
Posted: Tue Feb 05, 2008 11:51 am    Post subject:
Lenses are definately something to pull to reduce weight. Power supplies may also work depending on how they are mounted (power supplies on a Marquee are easy to pull, not so sure on a Barco).
Just be careful if you try to put some of the boards in your carry-on Wink
paw
Posted: Wed Feb 06, 2008 5:40 am    Post subject:
I believe the lenses are about 10 lbs each. Those alone might get you under the limit. They're easily to pull with a long, straight blade screw driver. The power supply? in the front of the 701 is easy to pull but doesn't weight much. The quadtrupler was a little bit of a pain to pull and maybe to put back in. I was/am parting out a 701s. It weight a few pounds.
So, you're going to duct tape a handle on it and call it luggage? Just remember, cargo handlers are not the gentle type. I'd talk the airline about this and luggage insurance.
Aubrey
jask
Posted: Wed Feb 06, 2008 6:59 am    Post subject:
check the dimensional restrictions as well,it may still be too big.
