Reset Nec Point convergence?
Juvental604
Posted: Sat Feb 02, 2008 8:36 am    Post subject: Reset Nec Point convergence?
Hello Im trying to do with the topic says. I seemed to have played around too much with my 100 point convergence and now i cant get it back to normal.
kschmit2
Posted: Sat Feb 02, 2008 9:56 am    Post subject:
Hit "Adjust", go to "4 / Convergence", hit "Enter", go to "8 / POINT", hit "Enter", push the "Normal" button on the remote, hit "Enter", then "Store" and "Enter"
Juvental604
Posted: Sat Feb 02, 2008 11:10 am    Post subject:
Hmm thats not working for me. I Have a PG 6 and when I push the normal button it goes into pin cusion convergence. Could it be something wrong with the remote? If so is there another way to reset it?
kschmit2
Posted: Sat Feb 02, 2008 1:07 pm    Post subject:
what's the exact model of the remote?
It does sound like you have an RC-6051 or RC-6351.
The PG uses the RC-6011.
Kai
Juvental604
Posted: Sat Feb 02, 2008 7:59 pm    Post subject:
Yeah it says Rc 6321 on it. So is there no other way to reset the convergence? Im getting quite a big bump on it.. maybe I should just try harder to even it out my self.
deronmoped
Posted: Sun Feb 03, 2008 1:35 am    Post subject:
You can turn off point in the options menu too.
Deron.
deronmoped
Posted: Sun Feb 03, 2008 1:37 am    Post subject:
Or if that fails, just pull the point board. You should not be using it anyways, if you are you have screwed something else up.
Deron.
kschmit2
Posted: Sun Feb 03, 2008 9:51 am    Post subject:
Deron.
Well, while it shouldn't be used for convergence per se, it still is useful for the final touch-ups. I.e. the last 0.5 percent to get you to perfect convergence.
Posted: Sun Feb 03, 2008 9:25 pm    Post subject:
Deron.
Turn it off in the option menu first! Or it may throw a point board failure error Smile
