optimal way of running satellite hddvd to nec xg852
ross
Posted: Sat Feb 02, 2008 4:26 am    Post subject: optimal way of running satellite hddvd to nec xg852
I have starchoice hd pvr and a dvd player running into a lumagen. The dvi output on the starchoice is sharper but needs gamma correction I believe for crushed blacks and green hue. Running thruough component cables, my starchoice looks soft likel there is less resolution but the colours are right. From my lumagen set at 720p output I run a high quality rgbhv to my xg852. I only have one rgbhv input on my xg852. I was thinking i should run the starchoice dvi out via a short dvi-hdmi cable into the moome ext hd and an hddvd player into the moome and then the moome dvi out into the lumagen dvi in. How does that sound?
