Marquee 9500 Fungus removal problems
SweetChuck
Posted: Fri Jan 25, 2008 12:53 am    Post subject: Marquee 9500 Fungus removal problems
I have fungus all over my red a blue c elements and finding it almost imposible to remove the c elements . I heard you can swish CLR around the chamber to get rid of it , Does this work ?? Confused
Posted: Fri Jan 25, 2008 6:24 am    Post subject:
I cleaned chambers with clr method, just 15 min with clr then 5 times rinse with disled water.. Then there was long period to wait until chambers dryed.
I filled chambers up to 1/4 with clr and moved/shaked those tubes that 15 min, all fungus was gone after that.
DVDO VP-50
New hobby, Rally
Posted: Fri Jan 25, 2008 8:16 am    Post subject:
Not sure if the CLR will attack the plastic lenses or not. It's fine on the glass Sony and other tubes, not sure on the C elements on an LC tube.
Posted: Fri Jan 25, 2008 9:23 am    Post subject:
I was worried about that also, I used Cillit bang bathroom cleaner. No melted c-elements here Thumbs Up maybe i was lucky Wink
DVDO VP-50
New hobby, Rally
SweetChuck
Posted: Fri Jan 25, 2008 2:53 pm    Post subject: Did It
I had the worry that CLR may attack the plastic , but went ahead anyway . I only left it in for 5 minutes of swishing around , followed by 10 distilled water flushes , thank god it worked , but what a major PITA Mad
While on a PITA subject , being new to the Marquee , why is the remote/user interface so retarded ?? , what a dopey interface Thumbs Down Thumbs Down Bloody nice projector though bar the f*cking stupid remote !!!!
nuttall_chris
Posted: Fri Jan 25, 2008 3:02 pm    Post subject: Re: Did It
What's wrong with the interface? I find it to be well laid out and almost every feature is quite intuitive. A Marquee 8000 was my first projector and I had no problems working my way through the menus to set things up.
Chris.
SweetChuck
Posted: Fri Jan 25, 2008 3:04 pm    Post subject:
What wrong with it ?? My opinion only . It needs 6 more buttons R G B off and R G B control function , like the Sony has . So easy .
