Video Enhancer 1.7
deronmoped
Posted: Wed Jan 23, 2008 6:59 am    Post subject: Video Enhancer 1.7
Anyone ever use this software to try and get a better image? I have no idea how it works or what it can be used on, but I find that it's real interesting that it uses previous frames to increase the resolution.
Video Enhancer allows you to
1) Increase resolution of your video with Video Super Resolution technique which delivers unbelievable quality by using information from previous frames, while all the other resize methods use information from one current frame. Now you can convert your SD video to HD!
2) Use hundred of VirtualDub video filters allowing you to do everything you want with your video : deinterlacing, denoising, deshaking, color correction, sharpening, visual effects etc.
Video Enhancer is a lot faster than VirtualDub because all filters and codecs work simultaneously in separate threads.
3) Open any video which can be played on your system and re-compress it with any video codec (DirectShow, DMO and Video for Windows) installed in your system.
Deron.
