Nec 6PG Video Input
Brooklyn
Posted: Mon Jan 21, 2008 3:58 am    Post subject: Nec 6PG Video Input
Hello, I am trying to get the Video input on my 6PG to work. I put the video card from my 9PG Xtra in my 6PG, but the video input still does not work. What else do I have to do? Can I even swap the video card from the 9PG Xtra in my 6PG?
Thanks!
Posted: Mon Jan 21, 2008 4:32 am    Post subject:
Not sure if you can do that. Doug?
dbaisey
Posted: Mon Jan 21, 2008 4:41 am    Post subject:
Been awhile but it should work. What PWC number is it and did you confirm it worked in the Xtra?
If yes and its a PWC3683 it should, did you have the input selected, the front switch set and a signal entry made? Doug
