Can someone confirm if this will work
Posted: Sat Jan 19, 2008 5:04 pm    Post subject: Can someone confirm if this will work
I'm getting ready to add HD-DVD and Blu-ray to my HTPC. I would like to do this as cheap as possible with what I have already. I'm running an AMD Athlon 4800+ X2 overclocked to 2.8Ghz on a Gigabyte GA-M59SLI-S5 motherboard with 1gig of DDR2 RAM.
Would this do the job: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125075
Is 256mb. of memory enough, I like this card and hope it will work as it doesn't have any fans and is (cheap) relative to other cards that I've been looking at.
Erik
Edited-sp
lyd
Posted: Sat Jan 19, 2008 11:07 pm    Post subject:
Seek other opinions, but it looks like it will work fine to me.
I posted because I had a question for you... If you are running an over-clocked X2, don't you have a hell of a lot of case fan noise anyway? Seems like the minimal fan noise introduced by an actively-cooled GPU would be lost in the background.
lyd
de gustibus non disputandum
Posted: Sat Jan 19, 2008 11:37 pm    Post subject:
lyd,
What do you recommend, I would like to around $100 or less.
I'm using a Zalman CNPS9700 HSF and it does a good job keeping the CPU cool while being quiet at the same time.
I'm OK with using fans as long as they are quiet (relative to other components) and are of good quality, so far with video cards I have had one with a quiet fan (Geforce 6800 with aftermarket HSF) one with a loud fan (Geforce FX 5500) and one I'm replacing has a fan with bad bearings that made it a very loud (Geforce 6200LE)
lyd
Posted: Sat Jan 19, 2008 11:50 pm    Post subject:
I don't think I'm a great one to ask for recommendations, I really haven't looked at the current crop very closely. Unless something drastic happens, I was planning to wait for hdmi video+audio solutions to evolve a bit more before I considered upgrading anything. All I can tell you for certain is that I'm currently using an EVGA GeForce 7900GTO, and have no complaints with it.
I'm pretty sure you'll get some more insightful advice from others here. Wink
lyd
Posted: Sun Jan 20, 2008 12:29 am    Post subject:
I wish I could do this but my 6200LE won't do HD-DVD no matter how much I want it to Wink
MikeEby
Posted: Sun Jan 20, 2008 4:09 pm    Post subject:
I use this one it works perfect with Vista and Powerstrip:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127308
Dirt cheap too $79 less $20 rebate, $59 after rebate.
Don't use the drivers that come with it. Download the latest from ATI.
Edit: You might consider another gig of ram too. DDR2 is very cheap now.
Good Luck!
Posted: Sun Jan 20, 2008 7:13 pm    Post subject:
I wouldn't expect much difference from any modern-ish video card for HT use. The only real differences are in 3D performance, which is irrelevant. You *might* argue that some of the deinterlacing/hardware playback is marginally better, but if you're using an HTPC there's no reason not to do it in software anyway.
Posted: Sun Jan 20, 2008 7:26 pm    Post subject:
True Peri however keep in mine the Geforce 8xxx series custom timmings are broken and the 8000 series cards don't work with powerstrip.
For gaming on a PC monitor, no problem though. Trying to get your 1080i/96 setup with proper pixle porches for you projector that's a problem.
Unfortunatly for HTPC ATi seems to be the choice.
ncc1701d
Posted: Wed Feb 06, 2008 10:50 pm    Post subject: Re: Can someone confirm if this will work
Yes it will work really well. I have a 2600xt/256 heatpipe cooled and hd-dvd and bd is at ~10% cpu hw accellerated (core2duo 2.66) .
Erik
Edited-sp
BG1208 and BG1208/2
