Sony G70 problems
jimmy.swe
Posted: Fri Jan 18, 2008 5:11 pm    Post subject: Sony G70 problems
Hello.
I bought one momme card and inserted in a Sony g70 and feed the projector with one hdmi cable from a blu-ray players.
But after that I had adjust everything so can I not adjust color and brightness and little other things if a press color button and this message came up “not Adjustable”.
Jimmy
r.bauer
Posted: Fri Jan 18, 2008 8:11 pm    Post subject:
Color can only be adjusten on video and S-video sources as they impact the color decoder.
Brightness and contrast can still be adjusted on RGBHV sources. A Moome card is an RGBHV source to the projector.
Axatax
Posted: Fri Jan 18, 2008 8:24 pm    Post subject:
You may have to into service mode for some of these adjustments. I don't think this necessary for brightness/contrast. If you don't have the input format for the B slot set correctly, the PJ not may see the card as an RGB source.
jimmy.swe
Posted: Sat Jan 19, 2008 9:05 am    Post subject:
Thanks for the ansver.
Jimmy
