PC monitor question
Posted: Fri Jan 18, 2008 10:42 am    Post subject: PC monitor question
My trusty CRT monitor finally bit the big one. I replaced it with a LG 24" widescreen 1080P LCD monitor. It has both HDMI and HD-15 inputs. For PC use, the image is best using the DVI output from the video card to the HDMI input of the LG using a DVI-HDMI adapter cable. That leaves my HD-15 input free. I had the bright idea to use this as a local monitor for the HT stuff. However, when I connect a break-out cable from the NEC switchers 2nd output card to the HD-15 input on the LG, I get a "NO SIGNAL" report from the monitor. What is happening here? Is the LG looking for some sort of hand shake from a PC to lock onto? Thanks,
