help a noob with a barco data 800
plicht
Posted: Thu Jan 17, 2008 8:54 pm    Post subject: help a noob with a barco data 800
I am entering the world of CRT projectors and recently bought a data 800.
I bought it from a very nice guy who was moving and didn't have any video source to connect to it. He powered it up and got it to display the set up screens and all three tubes were working.
Now I have it home connected to a dvd player and it powers up but I get no picture, nor can I get the set up screens when I press the adjust button on the controller. In fact, I cannot get anything to happen with the tubes at all. The red power light on the back comes on. I press standby and it turns green. All the voltage lights come on except the scan fail light which is not on. There green light on the SMPS board. The EHT fuse and SMPS main fuses are OK. On the controller unit the standby power, main power and block match lights are on - solid red and the processor cycles light is blinking?
I have been going through the set up guide and troubleshooting tips and am not sure what to do next. Any ideas?
I also have a graphics 1208 that has a bad quadrupler in it that I can get parts from, if there are any parts that are swappable that might be my problem.
Peter licht
scoobydoo
Posted: Thu Jan 17, 2008 10:41 pm    Post subject:
Peter
download a manual and make sure its reading the right input source (ie. S-video)
use the key pad under the cover to switch to the right source.
plicht
Posted: Fri Jan 18, 2008 12:42 am    Post subject:
Thanks. I have connected to the rgbhv port and the video port with no results on either. I can't even get the adjustment display to work. I shouldn't need a video feed to get the adjustment grid with those dots, should I? When I press the adjust button on the keypad, I should see something no?
Peter
ronholm
Posted: Fri Jan 18, 2008 3:35 am    Post subject:
Peter
yes You should see something.
Did the remote come unplugged somehow?
Posted: Fri Jan 18, 2008 3:36 am    Post subject:
Is the red light on on the EHT board?
plicht
Posted: Fri Jan 18, 2008 7:36 am    Post subject:
No the Red EHT light is not on. I checked the eht fuse too. It is OK.
And no, the remote is not unplugged. The standbye switch works - turns the fans on and turns the light from red to green on the back of the set.
ronholm
Posted: Fri Jan 18, 2008 2:42 pm    Post subject:
I had to ask.. If it were me ... Well Laughing
Posted: Fri Jan 18, 2008 3:00 pm    Post subject:
It sounds like either the SMPS or the EHT board is bad. Let me know if you want to send them up for testing.
Oh, the H shift boarc could be bad as well.
plicht
Posted: Fri Jan 18, 2008 4:07 pm    Post subject:
Ok. Thanks. I will send them in. I was thinking it was something grossly obvious that I had overlooked since I have never done this before.
In the meantime, Can I swap the boards from the Graphics 1208 that I have?
Peter
Posted: Fri Jan 18, 2008 4:11 pm    Post subject:
Nope, those boards are totally different, sorry!
