Flickering on green tube of 1292Q
MYoung
Posted: Thu Jan 17, 2008 5:45 am    Post subject: Flickering on green tube of 1292Q
I have noticed that I occasionally get flickers of magenta when watching content on my 1292Q. I threw up a test pattern to make sure that it wasn't my source. I found I especially get it on the test patterns. I then cut off the red and the blue tubes thinking that the magenta I was seeing was really just an absence/problem with green, which it was. This is only happening on green. Red and blue are clean. What I see reminds me of a loose composite video connection -- how the picture just flickers and gets garbled. It is intermittent, though it seems to have been getting worse, though it's not like I put very many hours on my 1292Q. I'll have to take some video of what I'm seeing. I know that's not too specific, but any clues as to what might be wrong? Perhaps a bad neckboard? I had a bad neckboard for the red tube that I replaced about a year ago. Man, was that was a bunch of fun! Fortunately, Graham Johnson is the man and helped me out! Though it was a different symptom then -- a black picture source appearing as dark red instead of black.
kypha
Posted: Thu Jan 17, 2008 6:03 am    Post subject:
I had that problem once with the ribbon cable that's attached to the top of the neckboard. It was loose
inside of that snap-type connector. It caused the red tube to shut off, flicker and bloom. You probably
checked that already, though.
Posted: Thu Jan 17, 2008 2:58 pm    Post subject:
If you've checked all the connections then try swapping that neckboard with another one and see if the problem follows or stays there.
MYoung
Posted: Thu Jan 17, 2008 4:37 pm    Post subject:
Thanks for the advice. I'll have to give that a try.
MYoung
Posted: Sat Jan 19, 2008 2:57 am    Post subject:
Re-seating cables leading to the green tube appears to have fixed it. Whew!
kypha
Posted: Sat Jan 19, 2008 1:09 pm    Post subject:
Which cables?
