problem with HD fury on my barco 808s
redhead123
Posted: Mon Jan 14, 2008 6:00 pm    Post subject: problem with HD fury on my barco 808s
I have purchased the HD fury green version with VGA to BNC with the 5 cable break out, red, green, blue, white and black wires that the web site suggested for the barco 808s. I am using direct tv HD HR 21-700 receiver. I am using the 25 ft HDMi/DVI-D 22AWE cable. The blue light on the HD fury is lighting nice and strong, we are getting a picutre from the projector but it has a pink tint to it where it washes the picutre out so you cant watch it.
I tried the 5 vault power supply that came with the fury kit. and it makes no difference. Can anybody help me out? Any help or suggestions would be appreciated.
Thank you John
r.bauer
Posted: Mon Jan 14, 2008 6:47 pm    Post subject:
Did you connect the R, G and B to the proper colors on the Barco? Pull out green and see if green disappears from the image.
Do you have the optional component board installed in your Barco , and selected port 6/7 on the barco bij mistake?
Is the H-phase properly adjusted. On some sources misadjustment can darken the picture.
Perhaps someone in China has mixed up the colors on the BNC connectors on the Fury adapter cable.
Your source isn't outputting component over HDMI instead of RGB?
medishka
Posted: Thu Jan 17, 2008 9:40 pm    Post subject:
hi everyone
l from france , and actually l use a barco 808S with PS3
l 've just buy a hd fury Red version , on port 3 trying to connect and l haven't picture ??? my hdmi cable are very short distance 1meter when l select on my remote n°3 is show only RVB2 60hz ?? and not picture
please some helps
regards
