Moome input memory structure for G70
Thornberg
Posted: Tue Jan 08, 2008 2:44 pm    Post subject: Moome input memory structure for G70
Is the input from this card seen as a component HDTV signal with only one memory block or is it seen a an RGB or computer input with many input memories.
I am using the component output of an AVR so every input source (PS3 - multiple resolutions, Wii - 480p and 720p, DirecTV - set as 1080i) has slightly different H &V frequencies. In the past every time I input a different source via the RGBHV card slot set as a "component HDTV" signal in the G70's menu I had to reconverge and resize. Actively converting the component to RGBHV allowed me to store the different inputs in unique memories because the projector interperets the sigmal as a computer resolution.
I would like to use the HDMI output so does this HDMI/component card store in the multiple PC memory blocks or the one and only component HDTV memory?
If you can't plug it in, don't ask me about it.
