Shift image vertically Barco 1208
ncc1701d
Posted: Sun Jan 06, 2008 6:38 pm    Post subject: Shift image vertically Barco 1208
My room does not allow me to have the screen high enough so i need to shift the image down.
I need about 5cm more on the screen (5mm on the phosphor?)
Rastershift is all way down, but there is more left on the phosphor, so how do i shift more?
on the sync/vert board there are vert shift pots for red and blue but none for green..
BG1208 and BG1208/2
r.bauer
Posted: Sun Jan 06, 2008 7:50 pm    Post subject: Re: Shift image vertically Barco 1208
[quote="ncc1701d"]
Rastershift is all way down, but there is more left on the phosphor, so how do i shift more?quote]
You can't. Only option is to alter the angle of the projector. Using that much raster shift might make it difficult to obtain proper geometry. Best option is to lower the projector by as much as LENS suggests.
ncc1701d
Posted: Mon Jan 07, 2008 12:53 pm    Post subject:
Ok, ill try to lower it then. Have to get a winch first so i can do all work myself.
BG1208 and BG1208/2
