Moose
| Posted: Sun Jan 06, 2008 3:39 pm Post subject: |
A forklift, maybe two, if you can fit then into your home, should do the trick.
_________________ In the real world, I am alan halvorson, King of the Wild Frontier and Swell Guy.
| Posted: Sun Jan 06, 2008 4:07 pm Post subject: |
I saw the 103" panels last year. THe heat emitted by that is insane. You will need some air conditioning, I'd hate to see the power consumption on that unit!
| Posted: Sun Jan 06, 2008 4:53 pm Post subject: |
> How does one install a 150" flat-panel?
VEEEEERRRRRYYYYY carefully...
zaphod
| Posted: Sun Jan 06, 2008 5:23 pm Post subject: |
well, first you bring it over to my house ....
| Posted: Sun Jan 06, 2008 7:28 pm Post subject: |
Hmm, 150" is 130.736"x73.539". That would make the pixels (if there are 1920x1080 of them) 0.0681"x0.0681". This is a little more than 1/16" and I'm wondering what a) if they can do this with LED, and b) what the fill-factor might be.
Curt, what do you think the power consumption might be to n-stack 9" CRTs to get the same size and light output?
Cozza
| Posted: Sat Mar 08, 2008 8:13 pm Post subject: |
Could you install a heat exchanger on the back to supply hot water for a typical house?
Ridebreck
Joined: 08 Mar 2006 Posts: 943 Location: Colorado Springs, CO
| Posted: Wed Mar 12, 2008 5:07 pm Post subject: |
I would love to see the wall bracket for that sucker.
_________________ "Hooray Beer!!"
| Posted: Wed Mar 12, 2008 9:00 pm Post subject: |
That thing is huge, resolution also isn't too bad considering the size (4k by 2k resolution).
I want one
JustGreg
| Posted: Wed Mar 12, 2008 9:06 pm Post subject: |
The presenter is pointing over his shoulder to an image on the screen of what you'll need to move it.
Cheaper than movers tho. It works for...........................................PEANUTS!
