Barco data HR (400 or 600)
nemmi69
Posted: Sat Jan 05, 2008 8:03 pm    Post subject: Barco data HR (400 or 600)
Anyone know anything about these units?
What doesn't kill you is only biding it's time
Ile
Posted: Sat Jan 05, 2008 8:27 pm    Post subject:
No sutch model in Barco Data product history sheet.
Do you have that R900**** order number from back panel sticker, that would tell much more.
Sonynut
Posted: Sun Jan 06, 2008 12:23 am    Post subject:
I had one.. not sure which model it is exactly, but its configured for "RGB" input(yea right).
One thing I DO know.. the module that plugs into the "remote" port is different than most. It has 3 switches along with the dials. Without this module it is useless. Video grade set, which means you'll be lucky to get an RGB 640x480 signal to work with it, unless you use a LOW refresh rate. If you are lucky enough to have the video board installed, you can run it with the BNC composite video port, but on mine the port was dead. I bet 320x240 RGB would work, but what use is that?
Good luck! I never could use the one I had(640x480 at its lowest refresh rate showed two desktops next to each other). I ended up ebay'ing it off for CHEAP. I think the buyer used it as parts.
1272 Stack coming soon:)
Posted: Sun Jan 06, 2008 4:08 am    Post subject:
Check the part numbers on the tubes. If they are SD 130 or SD 187, then pull them and get an ECP with toasted tubes. If they are the old Clinton tubes that have lead shields around the bell of hte tube, turf the set completely or play with it for fun..Smile
nemmi69
Posted: Mon Jan 07, 2008 4:32 pm    Post subject:
Bl**dy typical that I can find a service manual for this but not for my 708 Mad
