nec pg9 plus kicking my butt
97ss150
Posted: Mon Dec 31, 2007 6:20 pm    Post subject: nec pg9 plus kicking my butt
hey guys, i have been working on getting my nec setup all weekend. i worked on it about a total of 10 hours, while i have made alot of progress, i am far from good. i am getting pretty frustrated with this thing now lol. i know it will be worth the work when i am done but good lord its testing my patience. anywho im close but i am unsure how to get everything where i want it. and when i try to save it says somethign about cant save due to no enty or something to that effect. it was working yesterday until i copied an imput to another slot now i can only get an image for a second while its flipping from one input to another. see if you guys can get me going in the right direction .ill try to get screen shots tonight
henry
HaydnG90
Posted: Mon Dec 31, 2007 6:23 pm    Post subject:
Do you have much experience setting up CRT's. The NEC's are considered one of the more difficult brands to set up, which is why I cut my teeth on a Barco 808S.
Posted: Mon Dec 31, 2007 6:26 pm    Post subject:
Read this, and follow it start to finish.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=4722.html
If you haven't wiped out all of your memory settings, you might be able to do a 'data copy' from one location to another and restore your work. If not, you have to start from scratch..Sad Do a signal entry first.
If your memory dumps again, you could have a bad system board, that can cause random memory dumping.
BradTheAggie
Posted: Mon Dec 31, 2007 7:26 pm    Post subject:
As a followup to other posts, let us know where you are, when you can host a setup party.
We will in turn let you know how much beer and of what quality will be required to lure us over. 8)
(bholman on the AVS forum)
Heywood Jablome
Posted: Mon Dec 31, 2007 7:48 pm    Post subject:
What he said!
97ss150
Posted: Mon Dec 31, 2007 9:07 pm    Post subject:
dude i have no issues at all with beer. hope yall like chicken express or hooters hotwings. i will hook u guys ip if yall can get me up and runnning for the superbowl all the guys from church and work are supposed to be coming over. i hate to disappoint
henry
Heywood Jablome
Posted: Mon Dec 31, 2007 9:10 pm    Post subject:
Yes, but where are you? We are a large and generous bunch, with people just about anywhere who can help in person (beer and wings being the most common compensation!)
Posted: Mon Dec 31, 2007 9:14 pm    Post subject:
I love Hooters hotwings, but I know nothing about setting up projectors.
97ss150
Posted: Mon Dec 31, 2007 9:19 pm    Post subject:
im in roanoke. which is by keller, southlake. 35(w)N to 170. right by cabelas. i can see alliance airport and tms from my house.
Heywood Jablome
Posted: Mon Dec 31, 2007 9:45 pm    Post subject:
OK... Now were gettin somewhere!
While my NEC Karma is pretty good, I'm in Massachusetts. Curt Palme is in British Colombia, Canada, the webmaster for this site is in the greater Toronto area IIRC, well... you get the picture.
C'mon guys! Buck up... Who is in the VA region?
97ss150
Posted: Mon Dec 31, 2007 9:47 pm    Post subject:
lol wow i didnt put that i was from the dallas area huh. yeah im in the dfw area of texas near dallas and ft worth.
Heywood Jablome
Posted: Mon Dec 31, 2007 9:50 pm    Post subject:
Roanoke TEXAS? Damn... I (obviously) assumed Virginia.
BradTheAggie
Posted: Mon Dec 31, 2007 9:51 pm    Post subject:
Do we have any NEC ragu's in dfw? I could help with a Marquee (as could others), and we have a few barco owners that I know of...
97ss150
Posted: Mon Dec 31, 2007 10:04 pm    Post subject:
lol yeah the almighty texas lol. ya i hope someone local is familiar with these
Posted: Tue Jan 01, 2008 12:50 pm    Post subject:
I do suggest you download the "tinman/feathers" PG setup guide located in the advanced procedures section of this site. Read through it and understand the terminology prior to going back in. Try to resolve all questions prior to starting the setup. From my experiance, NEC is not one of the hardest to set up, it is the hardest. However, if you follow those instructions to the letter, you can make it work for you. As no one else has mentioned it here and I hope it's not to late, DO NOT TOUCH ANY INTERNAL ELECTRICAL ADJUSTMENTS. If you do it will be out of calibration and require re-calibration with a scope. With that said, the biggest problem with a NEC and someone new to CRT is they don't take the mounting of the projector seriously enough. There is no fudge room here. it must be exact. If not, you will struggle and never be rewarded with what the PG can really do. One correctly installed and set up is eye candy. There are higher resolution, more expensive projectors out there but none of them can beat the PG for color reproduction. Yes, even the mighty G-90. For all it can do, in stock form doesn't hold a candle to the PG in the color reproduction department. Razz
97ss150
Posted: Tue Jan 01, 2008 2:23 pm    Post subject:
no i havent touched any of the trimpots or anything like that. i would like to ceiling mount it but my ceiling doesnt allow for that.
97ss150
Posted: Tue Jan 01, 2008 2:28 pm    Post subject:
im not having any luck finding that post either i have searched for it as i have heard about it before
dbaisey
Posted: Tue Jan 01, 2008 2:44 pm    Post subject:
http://www.curtpalme.com/NECPG_MechSetup1.shtm
97ss150
Posted: Tue Jan 01, 2008 2:49 pm    Post subject:
oh ok i never knew that was the one her wrote. i have read this about 10 times lol
dbaisey
Posted: Tue Jan 01, 2008 3:15 pm    Post subject:
It sounds like your not hitting on the signal entry you made that your working on and why it says 'can not store no signal entry'
When you do a signal entry name it so you can check that your staying on it. In the settings turn on 'manual' menu so it will stay up on the screen. Check this as you go along. (Don't forget to put it back to auto when done)
If you have a similar signal entry already it could be going to that instead of what you entered. You can try to put your signal entry at the top of the input list so it will hit on it first. The projector multi syncs from the top of the input list working its way down until it finds a match.
Each change of resolution needs to be entered in the entry list. ie: 1080I, 720P, etc. When making a signal entry make sure you select the right input ie: video or RGB. Its also helpful to select 'temporary' at the entry so it doesn't go to the 'default' that was stored before or that may have been stored to default by mistake. When you get all done you can store the ' nice' settings to the default area.
Keep an eye on the signal name your working on. (Also the input) if you loose it. Doug
Note: Check your HDSTB video settings and unselect 'native' or if it has mulit selections unselect all except for one like 1080I so it will force one output resolution. Later when you get things under control you can add 720P but you dont want the HDSTB to be changing output freqs when you change channels. Some channels are native SD 480P, 720P, most are 1080I. Discovery HD is a good 1080I native channel.
