I need a volunteer good with making graphics...
Goto page 1, 2, 3  Next
Posted: Mon Dec 31, 2007 3:32 pm    Post subject: I need a volunteer good with making graphics...
... to help update my FAQ. I am writing up an addition that covers the zillions of questions that I get now about:
'how do I hook up my multiple sources to my projector?'
I get about 3 of these calls/emails a day, and they are very time consuming to answer. BY adding some text and graphics to the FAQ, I can answer the question with a couple of clicks and a link... Thumbs Up
I can write the text, I need someone to come up with some simple graphics, a la:
http://www.curtpalme.com/CRTPrimer_19.shtm
Simple, and to the point.
Your reward for doing this?
Cash-wise, well, nothing, we're a low budget operation here. Thumbs Up
On the plus side, I can compensate you with a repair or some part you might need. Plus, your name will be in lights on the side, we'll give you credit for the graphics..Smile
Let me know!
Joust
TV/Projector: Marquee 8501LC
Posted: Mon Dec 31, 2007 3:51 pm    Post subject:
I can get this done.
Not home right now. gimme a week.
zaphod
Posted: Mon Dec 31, 2007 5:44 pm    Post subject:
yeah, that's up my alley too.
Posted: Mon Dec 31, 2007 5:48 pm    Post subject:
Pick me, pick me! I'm a graphic designer who actually needs some parts!
If Joust or Zaphod don't want to do it, I'll definitely do it.
Posted: Mon Dec 31, 2007 5:57 pm    Post subject:
I'm writing up the article now and will post the Word document here shortly. I knew there'd b e more than one person responding. No fighting now, I'll leave it up to Kal as to what documents to use..Smile
Posted: Mon Dec 31, 2007 6:23 pm    Post subject:
Ok, here it is. Critique away if I've omitted anything...
crt projector tome 3- input switching.doc
 Filename:  crt projector tome 3- input switching.doc
 Filesize:  43 KB
 Downloaded:  412 Time(s)
Posted: Mon Dec 31, 2007 7:05 pm    Post subject:
I'm hurt! So my graphics on this and this page aren't good enough for you? Smile
Someone else can make them for ya if you want, otherwise I can do them the same way too... (I used Visio - they're pretty fast to do as they're so simple).
Posted: Tue Jan 01, 2008 9:10 pm    Post subject:
Sorry Kal, have at it. I figured with the updates and stuff that I'm working on, I'd be putting a lot on your plate this month.
Continuation of the graphics that are already on the site is fine..Smile
Posted: Tue Jan 01, 2008 9:14 pm    Post subject:
No problems. The last few months were slower so no biggie. If others wants at 'em by all means go for it. Less work for me.
Posted: Tue Jan 01, 2008 9:15 pm    Post subject:
Not just fine but outstanding ! Thumbs Up
Posted: Tue Jan 01, 2008 9:21 pm    Post subject:
You guys battle it out..Very Happy THe faster it's up, the less emails I have to answer..Wink
Fujifrontier
Posted: Tue Jan 01, 2008 10:21 pm    Post subject:
speaking of, did you get mine about the CCQ cable?>
Posted: Thu Jan 03, 2008 5:34 am    Post subject:
Guys,
I hope nobody minds, but I decided to run with this. I need some help from Curt on a projector and I can't afford to spend much money, so I decided to run with the graphics. I decided to try to take them up a notch from the established style (no disrespect for your work whatsoever, Kal - you do an AWESOME job with the web site.)
I'm about half done with them - should be finished in an hour or so... What do you guys think of this sample?
Sample diagram. You likey?
 Filesize:  24.99 KB
 Viewed:  10475 Time(s)
MikeEby
Posted: Thu Jan 03, 2008 6:06 am    Post subject:
People actually call and write you about this stuff? Geez...and they just expect free answers? I don't know how you make a living?
ecrabb... those do look nice, the color adds a nice touch.
Posted: Thu Jan 03, 2008 9:05 am    Post subject:
Curt,
Here ya be! The Word doc with all the JPG's in place of your graphic description text. The graphics have some "tick-marks" I was using to cut them apart (which need to be removed), the size and placement need to be adjusted, and I'd bet money you'll find an error or two. So, look them over at your convenience, make remarks, I'll tweak and send to you and Kal.
Hope you like them!
PS - I added an "Example 10". It's my system. Wink I think it'll probably make a few people's ears smoke, but I think it's pretty unique in how I use a matrix switcher and transcoder. See what you think.
crt projector tome 3- input switching_ecrabb.doc
 Filename:  crt projector tome 3- input switching_ecrabb.doc
 Filesize:  519.5 KB
 Downloaded:  503 Time(s)
Posted: Thu Jan 03, 2008 2:06 pm    Post subject:
Nicely done! One critique though in example 1.
THe typical a/v receiver does not have video and Svideo to component conversion, so you'd also have to have video and Svideo lines running from the scaler to the receiver. I'd change the cable box to read 'non HD cable box', and have it and the DVD player run Svideo lines to the a/v receiver. THen run a video and Svideo line from the a/v receiver to the scaler.
Also, Figure 3: I'd add 'HDMI card installed in projector'.\
Example 1,2,3,4: Have the DVD player read 'non hi def DVD player' since the older scalers can only process a 480i component signal.
Example 6: The RGBHV a/b switch isn't labelled.
Posted: Thu Jan 03, 2008 2:07 pm    Post subject:
Revised document with some text changes:
crt projector tome 4.doc
 Filename:  crt projector tome 4.doc
 Filesize:  521 KB
 Downloaded:  448 Time(s)
Posted: Thu Jan 03, 2008 3:45 pm    Post subject:
Very nice SC! I was hoping you'd take this on as I've always liked your graphics work. I'm the first to admit I am *NOT* a graphics designer. I just know what I like when I see it... Smile
Let me know when the document's done and I'll move it to the site as HTML ...
Z-Photo
Posted: Thu Jan 03, 2008 6:40 pm    Post subject:
I could do it also - but I would have to add bikini models...
Engineer by Day
Photographer by Night
My Portfolio
9kids
Posted: Thu Jan 03, 2008 7:35 pm    Post subject:
With so many new AV Receivers supporting HDMI switching, you might want to add an example like this.
 Filesize:  13.44 KB
 Viewed:  10348 Time(s)
Page 1 of 3
