barco 1209s not fully powering up
royuk
Posted: Sun Dec 30, 2007 8:09 pm    Post subject: barco 1209s not fully powering up
I'm new to the fan club and having problems all ready!
My recently purchased 1209s has suffered a fault.
Being a newbie i've had to take a crash course on the set-up and installation, while being guided by the seller and these forums.
I was half way or more in closing the rear cover for the main boards, after adjusting the pots for red and blue on the vertical board when suddenly the pj went mad with a clicking noise and the power going on and off before i could reach the main power switch.
What i can say at this stage is this: ( with focus/horiz/vert boards removed )
Pj partially starts up then shuts down. Tries again and then totally powers off.
G2 diagnostic board- 2 leds remain unlit :
HTHD - off
-17v - off (beside scan fail red led)
controller board:
stdby led : on
power cycles led : flashing
error led : on
with other 3 boards in:
HTHD - off
-17v - off (beside scan fail)
scan fail - on
+conv overvoltage - on
remaining green leds on except +conv
We think it could be the smps. Will be sending in for testing. In the mean time, if anyone has any thoughts?
thanks
Ile
Posted: Sun Dec 30, 2007 10:05 pm    Post subject:
Check those yellow wires near rear cover, maybe one of those wires got stripped and caused short...
Posted: Mon Dec 31, 2007 12:37 am    Post subject:
That would be the controller.
royuk
Posted: Mon Dec 31, 2007 12:20 pm    Post subject:
Ile Thumbs Up
Your spot on.
That was the first thing i did after it happened.
There is a small nick in one of the yellow wires that run out from the controller.
It's not cut through but you can see bare wire.
There should be conduit or similar covering those wires.
Bad design IMOP.
What do i do now?
It has obviously damaged something as it won't restart fully.
Ile
Posted: Mon Dec 31, 2007 12:56 pm    Post subject:
Tape that stripped wire and put cable spiral to that controller cable...
Measure all fuses in the smps with ohm meter, also those small soldered output fuses.
http://www.curtpalme.com/Barco808_Layout6.shtm
Probably one of those are burned and maybe also main fuse.
royuk
Posted: Mon Dec 31, 2007 2:52 pm    Post subject:
Excellent info: Thumbs Up
thanks for your much appreciated help!!
Will take a few days to test now, with holidays and all.
Let you know how i get on later in the week/weekend.
For now, thank you and:
*** HAPPY NEW YEAR ***
royuk
Posted: Wed Jan 02, 2008 10:23 pm    Post subject:
FANTASTIC NEWS! Very Happy
Checked smps fuses and F201 was blown.
Got it fixed and replaced board into 1209s to-day.
Pj is now working fine!
Thumbs Up ILE , you have saved me so much time and MONEY!
*It's guys like you that make these forums*
Not all good news though.
The Blue tube now has speckles jumping all over it.
I took off the only Red cable going to the focus block when pj was not working.
The end of it looked corroded but when i put it back i wasn't sure how to connect it.
It was under the rubber boot covering the cable end and focus block 'pin'.
Not sure if it was touching or just close?
Any ideas?
royuk
Posted: Sat Jan 05, 2008 4:19 pm    Post subject:
Blue is no longer working properly so i'm looking at the rgb card.
I have also posted as a new thread on avsforums.
royuk
Posted: Sat Jan 12, 2008 10:14 am    Post subject:
UPDATE:
PJ is now working fine.
Don't know what the problem was but it has sorted itself out!
Very Happy
Barry
Posted: Sat Jan 12, 2008 9:37 pm    Post subject: Ile is not a regular member...he is a god!
Yet another instant diagnosis spot on!
Barry
Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
