| Posted: Sun Dec 23, 2007 5:24 am Post subject: Moome DVI card problem...component inputs don't work |
I've been using a Moome DVI card in my Marquee for some time now.
I've been using the DVI input via a 24 foot cable from my HD cable box.
Now I've got a Blu-Ray player (A Sony BDP-300) and I went to connect it via its component outputs
to the Moome DVI card's component inputs. It was set to 1080i, which the Moome card can handle.
I've used those component inputs before, with the cable box, so I KNOW they worked at one time.
I'm unable to get anything via the component inputs. The Marquee returns NO SYNC.
I tried switching the cable box to the component inputs, which HAS worked before, and that didn't work, either.
I messed with the preferred source selector switch and even unplugged the DVI cable entirely.
Still no response via the component inputs.
Any ideas of what might be wrong? I find it hard to believe that the Moome card might have failed.
CJ
Bert Randolph
| Posted: Sun Dec 23, 2007 2:48 pm Post subject: |
I have the same issue with the DVI-Input of an XG card. I have used it before with no problem, but now its just as if there is no source connected. YUV works fine. I suspect it is some solder point that has gone bad, because pressing at the DVI port did help at the beginning. Now it is completely dead
I will resolder when I have time.
Daniel.
