Any Ideas?
VegasDan
Posted: Thu Dec 20, 2007 10:24 pm    Post subject: Any Ideas?
Hey guys, question for you... I have a Sony 1270 and it keeps shutting off as it is warming up. Usually, it'll do it about 1 min into warm up and won't re-start for a couple of minutes. Then, it'll do it again 8 or 9 minutes in, this time not allowing re-start for 10-15 minutes. Third time is usually ok, but every once in a while it shuts off randomly during the movie.
Any ideas as to what may be causing the shutoff and what I might do to fix it? Thanks.
Sonynut
Posted: Thu Dec 20, 2007 10:51 pm    Post subject:
Check that all the large fans spin as they are supposed to.. beyond that the easiest thing to do is try to buy/borrow an L board out of a newer 12xx to get the error code.
1272 Stack coming soon:)
mike calcott
Posted: Fri Dec 21, 2007 2:23 am    Post subject:
I had one with a similar fault, it turned out to be one of the transistors was not bedded into the heatsink properly
Old dog learning new tricks
Posted: Fri Dec 21, 2007 2:33 am    Post subject:
I think Curt usually recommends pulling boards, cleaning contacts, and reassembling. These old projectors are nearing 15 years old...
VegasDan
Posted: Fri Dec 21, 2007 11:27 pm    Post subject:
Thanks for the input. I realize that the projector is getting old. But honestly, I'm CRT challenged. I wouldn't know how to pull the boards out without electrocuting myself or dropping the thing on my head. Wink Any ideas as to where I might find a pro to do it? I live in Las Vegas.
