rds
Joined: 13 May 2006 Posts: 16 Location: rosario argentina
| Posted: Thu Dec 20, 2007 12:42 am Post subject: barco 808 disamble |
Hi all,
I need yours advice to remove the upper plastic lateral cover in the left side of my barco gr 808s to change the cuadrupler (or multiplicator of tension) it`s in the left back corner and is attached with bolts to the chassis and need apart the plastic body to access the bolts.
Thanks!
Rubén
| Posted: Thu Dec 20, 2007 1:05 am Post subject: |
Take off the 4 screws holding on the side panel. Lift it off. That exposes the quadrupler screws.
I then take the one side screw off that holds the back metal part of the case. That will allow you to bend back the back cover slightly to give better access when pulling the quadrupler out.
rds
| Posted: Thu Dec 20, 2007 1:13 am Post subject: |
Hi Curt,
Ok but the plastic have a dents that fit in the chassis , they unlock forced to down?
Thanks!
Rubén
Z-Photo
Joined: 07 Mar 2006 Posts: 2749 Location: Huntsville - Alabama
| Posted: Thu Dec 20, 2007 2:34 pm Post subject: |
The side just has the four screws and is hung on tabs - like Curt said remove the screws and lift the side off.
_________________ Engineer by Day
Photographer by Night
My Portfolio
rds
| Posted: Fri Dec 21, 2007 3:13 pm Post subject: |
Hi guys,
Thanks I remove the cover and change the cuadrupler.
Now my pj is runing again with colored glycol and with a new stewart ultramatte 180.
Rubén
