Shivery image -- is this a losing sync thing?
lyd
Posted: Wed Dec 19, 2007 11:31 am    Post subject: Shivery image -- is this a losing sync thing?
I've noticed that my 8500 does this sort of horizontal wiggly thing. It seems to do it more when I have just turned it on, and more in high contrast areas. Around the text on my desktop, when displaying an internal grid pattern, etc. I am seeing this at 720p/60.
Seems to calm down after it has been running for a while, although I haven't had a chance yet to test that thoroughly.
Does anyone recognize what I am describing? I'll be re-doing my setup, starting with physical positioning, over the upcoming holiday. I'm wondering if that will sort this, or if there is something else I need to be looking at.
Thank you.
lyd
Posted: Wed Dec 19, 2007 3:26 pm    Post subject:
Does your marquee have origninal fans? My 8500 had unstable rasters when it had silenx fans on belly, I replaced those to Papsts and got much stable picture.
DVDO VP-50
New hobby, Rally
lyd
Posted: Thu Dec 20, 2007 11:25 am    Post subject:
It does have original fans, afaik, but is that really likely to be the root cause of the problem? It is hard to imagine that they all do this...
lyd
Posted: Thu Dec 20, 2007 11:36 am    Post subject:
Ok. then that must be something else.. Original fans are shieldet better than "computer fans" and those could make rasters to vibrate. Trye to clean contacts and reseat boards.
DVDO VP-50
New hobby, Rally
lyd
Posted: Thu Dec 20, 2007 12:17 pm    Post subject:
Ah, I see. I misunderstood your first reply; I thought you were saying that the stock fans were silenex.
All the internals on this thing are extremely clean, but I'll try removing and reseating the boards again after I am done repositioning it.
lyd
Posted: Thu Dec 20, 2007 2:32 pm    Post subject:
Sorry..My English is quite bad.. Lets hope that you found culprit Thumbs Up
DVDO VP-50
New hobby, Rally
lyd
Posted: Thu Dec 20, 2007 8:09 pm    Post subject:
Hey, I'm pretty certain that your english is better than mine, 1031. Wink I just didn't parse it correctly. Thanks for the response.
lyd
