tube replacement
linetrig
Posted: Tue Dec 18, 2007 11:13 pm    Post subject: tube replacement
got new to me tubes for my barco 708
came from a dwin hd700 in much better shape than current tubes
which tube would be the best to start with?
should i set all controls to midpoint?
Barry
Posted: Tue Dec 18, 2007 11:43 pm    Post subject:
The best to start is here: http://www.curtpalme.com/TechTips.shtm
And then there are topics here with some step by steps: http://www.curtpalme.com/Advanced_Procedures.shtm
If I might editorialize though, it seems like a lot of work for a 700 series when there are a ton of good condition 808 Barcos for sale cheap, or even 1208,9s.
Also, this one is for the 800 series but I suspect that a lot of the tips should apply: http://www.curtpalme.com/docs/BarcoGraphics808s_CRTReplacementProcedure.pdf
Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
linetrig
Posted: Mon Jan 14, 2008 7:50 pm    Post subject: tube hv lead
was removing silicone to remove old lead and the old silicone completly fills
boot and hole for lead to connect to tube point where i had to cut the boot to
get lead out.
can this cause lead to leak and arc?
leads were not like the ones on the origanal tube boot was much larger.
