hot Marquee tubes
Rdean
Posted: Fri Dec 14, 2007 3:40 pm    Post subject: hot Marquee tubes
I am turning a M8000 into a M8500. I did the anamorphic mod to the verticle board and installed the entire 8500 rear heatsink unit to the 8000. Not sure what other parts are original to the 8000 as I have bastardized several Marquees over the years.
Anyway, when I powered up the green looked fine, was dark except the "No sync" message. But the red & blue were lit up bright, they should both be dark with no signal present.
I remembered to pull P14 before I powered down, so no spot burn occured.
I have not had a chance to try another verticle board yet. Is that most likely the culprit? In what conditions will a tube's raster run hot like that?
Posted: Fri Dec 14, 2007 3:50 pm    Post subject:
Sounds like the G2s are set too high. THat's all.
Rdean
Posted: Fri Dec 14, 2007 5:25 pm    Post subject:
Oh right, that makes sense. Those values are probably held in the control board which came out of a very high hour machine.
Thanks!
Posted: Fri Dec 14, 2007 5:29 pm    Post subject:
Correct. Ramp those down and you'll be fine.
