G90 YA Board Removeal
Frank D
Posted: Sun Dec 09, 2007 3:45 pm    Post subject: G90 YA Board Removeal
When removing the YA board from the G90 must you kill the power using the hard switch on the back of the G90 or can the board be removed while the G90 is in standby mode?
When removing any board is it best to have the G90 hard switch off or can some be removed while the G90 is in standby mode?
Atom
Posted: Sun Dec 09, 2007 3:49 pm    Post subject:
Hi
You should completely remove power before removing any boards.Unplug it to make sure.
Andrew
