d50q problems
d50q
Posted: Sat Dec 08, 2007 9:29 pm    Post subject: d50q problems
ok here goes my d50q does some strange stuff
at first i could not get the remote to work at all then Curt told me about the 2 switchs on the back of the unit and to set them to 00,01 i did and i can get the remote to work only with the s cable and the setting in the menu is on
Curt told me about the 4 dip switches on the back of the a boad i set them as he suggested
and still no only works with the s cable
the second problem i am having is when i first fire it up with no signal all tubes fire up and then blue and green turn off
red stays on but at a low glow not full power someone suggested it could be the cr board on the red tube
does this sound right? anyone have a spare?
also on the a board there are 4 dip switches and a small switch also a momentary switch sw202 i think
what should they be set at as the 4 dip switchs are on the on position
when i set the small swtch to normal i get error codes 60 and 7
d50q
Posted: Sun Dec 09, 2007 3:18 am    Post subject: remote has no ir components in it
http://www.hammerheadtech.com/commerce/catalog/product.jsp?product_id=17759&czuid=1197169857547
check out this link could this be the issue with my remote not working
maybe it does not have the ir components in it hm i will have to open it up
Posted: Sun Dec 09, 2007 6:56 am    Post subject:
Any error codes displayed?
Tinman
Posted: Sun Dec 09, 2007 5:21 pm    Post subject: Re: remote has no ir components in it
Yes, a wired remote does not have the IR components. Might want to check on that.
Marc
This space for rent.
d50q
Posted: Thu Dec 13, 2007 6:32 am    Post subject: its an ir remote
the remote has the ir components
i sure wish the d50 parts were easier to come by
why are they so rare?
