Scan lines visible when nodding!
radar
Posted: Wed Dec 05, 2007 4:03 am    Post subject: Scan lines visible when nodding!
Hi There,
I have a 1001qm and when I'm looking at the screen and nodding my head (may sound crazy, but if someone is offering XXX, one may nod vigorously).... I notice the scan lines. If I keep my head still, its not there. Does that mean the bandwith (Mhz) or the interlacing of the machine is slow enough for the scan lines to be visible in this condition? So if I upgraded to a better CRT, should I go for a higher bandwith or higher resolution (or both)? Or does this have nothing to do with the scan lines being visible (under these conditions)?
XXX means beer by the way!
Posted: Wed Dec 05, 2007 5:16 am    Post subject:
Yep nothing like 8 foot wide por....beer. Very Happy
Posted: Wed Dec 05, 2007 5:44 am    Post subject:
This explains it:
http://www.curtpalme.com/CRTPrimer_14.shtm
David_Web
Posted: Thu Dec 06, 2007 6:03 pm    Post subject:
I take it the signal is interlaced and that would indeed be the cause of it.
As interlaced is only sending half the lines at once it will draw the other part black (in reality it will just skip the line)
When nodding your point of view will change so that the drawn lines will sit ontop of each other with a black line between them.
In effect it won't really matter how fast you update the screen but how fast you move your head. However at higher frequencies it might be harder to notice it.
It has not really anything to do with the "sweet spot" of the pj but how interlacing works.
dbaisey
Posted: Thu Dec 06, 2007 6:32 pm    Post subject:
Isn't the 1001g a video only projector? If so you will need more XXX or upgrade to something with a higher kHz value and bandwidth.
1080I is 33 kHz and 720P is 45 kHz. Yours is 15.75 kHz 480I (video). Something in the 65 kHz range is about right. Doug
Tinman
Posted: Thu Dec 06, 2007 8:18 pm    Post subject:
Don't nodd your head!! Very Happy
Marc
This space for rent.
Posted: Thu Dec 06, 2007 8:56 pm    Post subject:
Exactly right: Motion makes scanlines stand out more.
By either moving your head fast, or stuff on screen moving fast, your brain sees the scanlines more as the scalines are the one thing that DON'T move. They stay still. So your brain focuses on those.
Posted: Thu Dec 06, 2007 10:41 pm    Post subject:
This guy has a hell of a time with that problem.
<obscure 5-year-old pop culture reference>
radar
Posted: Fri Dec 07, 2007 12:21 pm    Post subject:
Thanks folks... that was really helpful. So, when I'm on the couch with the girlfriend and she asks if I want any xxx, I nod vigorously and I suppose I'd forget about the scan lines anyway. Alternative two is to upgrade and get one which has a faster scan rate/frequency and agree with the girlfriend slooooowly!
papalek
Posted: Fri Dec 07, 2007 12:33 pm    Post subject:
If you upgrade to one that does 720P then you can nod very fast. It is progressive so you will not see the interlace artifact.
I do love my AmPro's
Posted: Fri Dec 07, 2007 6:10 pm    Post subject:
Hell at 720P your girlfriend could 'nod' faster too. Wink
JustGreg
Posted: Fri Dec 07, 2007 6:58 pm    Post subject:
Oh no you di-ent!! Laughing Laughing Mr. Green
Oh wait. You're Canadian. That probably means something different than "bob". Mr. Green
Greg
Greg
Posted: Fri Dec 07, 2007 11:39 pm    Post subject:
Yeah and her two friends Neil and Bob.
tri_joel
Posted: Sat Dec 08, 2007 4:22 am    Post subject:
Just say no.
www.vawinesnob.com
Posted: Sun Dec 09, 2007 3:36 am    Post subject:
Hey now be polite. Just say "No thank you" Mr. Green
Posted: Sun Dec 09, 2007 3:46 am    Post subject:
I believe it's XXXX, not XXX.
And while it may come in a can, it most certainly is NOT beer.
Posted: Sun Dec 09, 2007 3:47 am    Post subject:
Ohhhhhh 4X BEER yeah ok, there's a brand of condoms called xxxx too.
