Not a again.. Marquee troubles
jantje112
Posted: Tue Dec 04, 2007 9:04 pm    Post subject: Not a again.. Marquee troubles
So, no love with my Marquee at this time.
My marquee won't give a picutere. It gives a crackle from the HV at startop, in my imagination not as loud as normal, but not sure. The projector won't give any errors. When it's "running" there is no image on the tubes and there is also no image on the tubes. I needed to adjust g2, because of a tube swap and didn't do that already, so I can see that there is no image at all.
Any ideas what to do first? How can i test what's wrong and need to be replaced?
Thanks!
Posted: Tue Dec 04, 2007 9:35 pm    Post subject:
Have you already swapped the tube. If so it may be as simple as a loose or missing connection, do you get internal menu's
Erik
jantje112
Posted: Tue Dec 04, 2007 9:37 pm    Post subject:
The projector worked, it stopped working. So the change of a loose connection is not big. I pressed and reseated everything. Also no menu's/pattern
Joust
TV/Projector: Marquee 8501LC
Posted: Wed Dec 05, 2007 12:47 am    Post subject:
pull the HV lead out of the splitter for two tubes. and test one colour tube at a time. see if it comes up.
can you tell if HV is on?
Z-Photo
Posted: Wed Dec 05, 2007 4:30 am    Post subject:
your lucky that it is not an ampro - they never work.....
Engineer by Day
Photographer by Night
My Portfolio
Posted: Wed Dec 05, 2007 5:15 am    Post subject:
Wow inventing Ampro bashing in a non Ampro thread. You'll make your quota for sure.
Posted: Wed Dec 05, 2007 5:23 am    Post subject:
Reseat the HDM, turn the set on and off twice and see if on the second power up, if any error lights come on on the back of the set.
jantje112
Posted: Wed Dec 05, 2007 11:54 am    Post subject:
Second time there are three red led's
the left one (error)
and the two at the right. h fail and v fail
Posted: Wed Dec 05, 2007 1:33 pm    Post subject:
THat sounds like a bad VIM. I've had those LEDs light up in error like that when the VIM went bad.
jantje112
Posted: Wed Dec 05, 2007 1:35 pm    Post subject:
Damn, it's a 03p VIM, that's not an easy one to find....
Can is check something simple to be sure it's the VIM?
jantje112
Posted: Wed Dec 05, 2007 1:38 pm    Post subject:
And can you repair it ?
Posted: Wed Dec 05, 2007 1:40 pm    Post subject:
Yes, disconnect the main connector cable that connectors the neck boards to the mother board. It's the one with the black wires and with multi-pin connectors on each end.
You can do one at a time, or start by pulling all three from the mother board. Don't worry about the RCA, leave them connected.
jantje112
Posted: Wed Dec 05, 2007 1:47 pm    Post subject:
Ok,
What should happen if I remove them? HV should turn on?
Posted: Wed Dec 05, 2007 1:51 pm    Post subject:
jantje112 wrote:
Ok,
Yep. If somehow the protect circuit was damage on any of the neck boards from you changing out the tube, the HV will not happen.
If you start out removing them all and the high voltage comes back, you should know what to do next.
jantje112
Posted: Wed Dec 05, 2007 4:13 pm    Post subject:
mp20748 wrote:
jantje112 wrote:
Ok,
I will do that first. FYI the projector did run after the swap, so most likely something went damaged.
Posted: Wed Dec 05, 2007 4:17 pm    Post subject:
You can also swap in any VIM, even one from an older 8000 and see if it fires up. the 8000 VIM will not work properly, but you will get a picture. I can repair the -03.
jantje112
Posted: Wed Dec 05, 2007 5:41 pm    Post subject:
Ok, finding a "spare" over here is difficult. But i will give it a try. The 8000 won't work, but will an 8100 and up do fine?
jantje112
Posted: Sun Dec 09, 2007 2:08 pm    Post subject:
Tried the suggestions. The HV will not come up. It makes an attemp, but won't come fully on. (Sounds stupid..)
Is an marquee 9000 projector a good source for a VIM, or is that also a not fully functional item?
Joust
Posted: Sun Dec 09, 2007 2:14 pm    Post subject:
any Vim from any marquee should work.
jantje112
Posted: Sun Dec 09, 2007 2:24 pm    Post subject:
@joust
This suggests other?
