NEC 9PG Saving Settings
tri_joel
Posted: Tue Dec 04, 2007 3:09 pm    Post subject: NEC 9PG Saving Settings
I spent several hours Saturday setting up my 9PG and was very pleased with the results. The power was out for a few minutes Sunday morning. Sunday night is family movie night, when I turned on the PJ the blue was out of convergence. I re-converged (is that a word?) and had a good PQ again. When I pressed store I got a message, don't remember exact verbiage, but it basically said I couldn't store at this point. We watched the movie and then I restarted the PJ and the blue was out of convergence again. What did I do wrong? Can I not just adjust convergence and save?
Joel
dbaisey
Posted: Tue Dec 04, 2007 5:18 pm    Post subject:
Joel,
You cant store unless the signal is registered 'entered'
If it said 'cant save no signal entry' you will have to re-enter the signal first then correct the blue. To store settings you have to hit the store button then hit the enter button.
When entering a new signal or in this case re-entering a signal that was somehow lost, name the signal entry so you can keep an eye on it.
Are you sure the signal properties didn't change on you when the power went out? Source defaulting to something different?
Could be a early sign of a system board problem but try doing a new signal entry first then correct and store-enter. Doug
tri_joel
Posted: Tue Dec 04, 2007 5:24 pm    Post subject:
Thanks Doug. I will try it in the next few days.
www.vawinesnob.com
dbaisey
Posted: Tue Dec 04, 2007 5:28 pm    Post subject:
Joel,
What is your location? Might put that in your profile. If you up in the storm areas this week Id wait. Brown-outs are hard on them. Doug
tri_joel
Posted: Tue Dec 04, 2007 5:44 pm    Post subject:
Updated my profile. I'm in Northern Virginia so I will not be receiving the bad weather this week. My neighborhood does loose power frequently for no reason though.
www.vawinesnob.com
