BarcoData 808 Port 3 problem
tomgilmartin
Posted: Sun Dec 02, 2007 8:29 pm    Post subject: BarcoData 808 Port 3 problem
I have a BarcoData 808 on which I have been using port 5, the 5 BNC inputs. I got an HDFury Red for Port 3, and when I connect it I get the "No Input Signal" message from the Barco. I connected he 6 inch HDFury cable from my normal transcoder output (the one that works on port 5) and still got no signal detected. Any idea why my port 3 doesn't work, other than the obvious that it's damaged somehow? Is there some setting for this, I looked all throuh the manuals and onscreen menus and couldn't find anything
In addition I connected the HDFury to an LCD monitor on the analog VGA input and with the same source I tried on port 3 it worked fine.
Thanks for any help!
Tom
Ile
Posted: Mon Dec 03, 2007 11:14 am    Post subject:
Many others have reported fury problems with port3. Using port5 have been best solution this far.
