How to force Negitive Sync on the EXT-HD?
dualtriamp
Posted: Fri Nov 30, 2007 5:43 pm    Post subject: How to force Negitive Sync on the EXT-HD?
I read that there are jumper settings for forcing negative sync but can find no documentation on how.
Posted: Fri Nov 30, 2007 6:13 pm    Post subject:
Moome: Can you provide us a picture and I'll add to the FAQ? Ideally the manual should have a listing of all jumper settings with their locations as well.
satguy2000
Posted: Sun Dec 02, 2007 2:16 am    Post subject: Negative Sync fix
Attached is the latest Manual which has the Negative sync jumper adjustments. I will test these later this evening and report to the group my results with the Barco 1208.
ext_hd_v11.pdf
 Filename:  ext_hd_v11.pdf
 Filesize:  108.58 KB
 Downloaded:  696 Time(s)
satguy2000
Posted: Fri Dec 07, 2007 5:48 am    Post subject: Re: Negative Sync fix
I did want to report that the negative sync does work as described.
moome
Posted: Fri Dec 07, 2007 8:29 am    Post subject: Re: Negative Sync fix
did you check the sync with scope?
