Barco 701 data problems.
lennart
Posted: Thu Nov 29, 2007 7:02 pm    Post subject: Barco 701 data problems.
Hi guys, hope someone can help me Smile
I've got a Barco 701 data pj that suddenly turned itself of when i was using it, no special sounds
or anything it just shut off and now when i start it up it reacts like its restarting itself without showing any picture.
I surely i hope someone can guide me to fix it Very Happy
David_Web
Posted: Thu Nov 29, 2007 7:15 pm    Post subject:
Any red LEDs lit?
lennart
Posted: Thu Nov 29, 2007 7:22 pm    Post subject:
When it restarts the red led nr 2 from the yellow one blinks under restart.
David_Web
Posted: Thu Nov 29, 2007 7:34 pm    Post subject:
On mine it's marked "SF"
And is located between Hold Down ETH and HD.
*edit* scratch that
According to the manual it's slightly different then mine.
What marking does it say above or below the led?
lennart
Posted: Thu Nov 29, 2007 7:46 pm    Post subject:
i actually cant find any markings on it.
But according to the manual ive printed before its the "SF" led that flashes when restarting.
David_Web
Posted: Thu Nov 29, 2007 7:56 pm    Post subject:
"The SF LED means that the set has a horizontal or vertical deflection failure. The HV will shut down as well when a scan fail occurs." <-- from the tips and manuals page on this site
Others will chime in and tell you what it means though.
It should be some markings on the set. It might be under the lid thought.
lennart
Posted: Thu Nov 29, 2007 8:02 pm    Post subject:
Ive looked at it again, and still cant find it. Maybe if i take the pj down from the ceiling and take of the bottom lid but i hope i dont have to take it down. Now i just wait and hope that someone tells me the solution for my problem Smile
