I2C Error BD808s HELP!!!
X-Ray
Posted: Tue Nov 27, 2007 5:27 pm    Post subject: I2C Error BD808s HELP!!!
Hi
dude i have a problem whit my BD 808s
i get it the i2c error's atfter i go out of the menus... bam bam bam..
its says I2C error and under it its lots of addressees under it.. it go's so fast i cant read the numbers there..
and when i get back to my desktop picture.. the picture is all fu..k'd up.. and seem's like the green tube is not on.. but is on in the menus..
it started with this weekend.. i fire it up and it bowled the fuse's for the living room.. well let me say it so.. i only got a 10 A fuse in my livingroom.. barco and amp's you know.. so i cant turn on to many amp's and **** before it blows
sorry my english sucks..
hope you can help my out here Smile
Posted: Tue Nov 27, 2007 8:02 pm    Post subject:
Umm, your first post, and you're pimping another CRT forum in your LARGE signature?
While you're not technically breaking any forum rules here, it's certainly not in good form....
X-Ray
Posted: Tue Nov 27, 2007 8:19 pm    Post subject:
oh sorry. dident know :s
Posted: Tue Nov 27, 2007 8:42 pm    Post subject:
Pull out the convergence tray and fire the set up. You'll get the same I2R error codes, but see if the rest of the set will work correctly. Sounds like the convergence driver card is bad, I can repair that.
Cheers!
X-Ray
Posted: Tue Nov 27, 2007 9:14 pm    Post subject:
Cheers!
ok will give it a go..
ok.. done.. well i got the I2C error when i fire it up now.. and i got true the set up.. butt then i got the I2C error one more time.. :/
yeah my remote don't work now more.. and i don't have the original remote to my 808 so i have a allinone remote.
well what will it cost me to send it to canada and back to norway + repairs?
Ile
Posted: Wed Nov 28, 2007 7:02 am    Post subject:
That's different problem, back ir receiver is probably broken. But you can use internal remote to test...
X-Ray
Posted: Wed Nov 28, 2007 11:57 am    Post subject:
yes that one work just fine
Posted: Wed Nov 28, 2007 1:07 pm    Post subject:
The I2R errors are normal without the convergence board. Does the green tube light up with the video image and can you post a pix of the test grids on the screen? If they look normal, then you can pull the convergence boards out of the tray and send them to me. Send me an email through the site and I'll tell you how to send them in.
Thanks!
X-Ray
Posted: Wed Nov 28, 2007 4:51 pm    Post subject:
Thanks!
Hi
the green tube don't light up on the desktop image. Sad
butt in menus it dos some times.
then you can pull the convergence boards out of the tray?? how many are there? haha
and my remote work now Smile
send it to the "djunkjard" Crying or Very sad
can you speak Norwegian pliz.. so i understand you Shocked hehe
Posted: Wed Nov 28, 2007 6:09 pm    Post subject:
The menus on the green should come on all the time with the menus. I think you just have a bad connection. Check all CRT connections around the CRT socket to see if something is loose.
X-Ray
Posted: Wed Nov 28, 2007 8:57 pm    Post subject:
nope.. still have the same problem.. no green tube in video mode.. Sad
Posted: Wed Nov 28, 2007 9:06 pm    Post subject:
OK, directly over each tube socket is the video output amplifier, bolted to the chassis with two screws. Change the green with the red, and see if the red goes dead.
I'll bet the green will come to life.
X-Ray
Posted: Wed Nov 28, 2007 9:26 pm    Post subject:
Ok.. Will try that to Tomorrow.
you will hear back from me Smile
its starting to get real late over the atlantic now..
well i'm not gone sleep good this night for sure.. Neutral
