Shorting out pins for G2 adj of a BG1208
rod
Posted: Tue Nov 27, 2007 3:30 am    Post subject: Shorting out pins for G2 adj of a BG1208
I seemed to have lost my collection of a million jumpers. When shorting out the pins for the G2 adj procedure can I use alligator clips? I'm afraid to short the pins against the box and I can't determine if the box is metal or not. Is there any danger to the pj or myself in doing this?
Rod
Ile
Posted: Tue Nov 27, 2007 8:38 am    Post subject:
Box is aluminium and it's connected to ground. Jumper connect ABL control loop to ground, so it's same thing if you accidentally short pin to box.
I once used screwdriver to short pins...
rod
Posted: Wed Nov 28, 2007 12:37 am    Post subject:
Kiitos Ile,
Always so helpful!
Rod
