Sony 1292 -> How to remove FAN Control ?
Brett
Posted: Mon Nov 26, 2007 10:37 pm    Post subject: Sony 1292 -> How to remove FAN Control ?
Hi Guys,
Some of you already know me from the early days of the AV Science forum. I've chosen this forum to post to as it seems to be the refuge of the hard core CRT crowd.
You may remember that several years ago I was among the early experimenters in fan mods for the Sony 1292 which worked fine for quite a while:
http://archive.avsforum.com/avs-vb/showthread.php?s=&threadid=66669
However, despite the workaround of the projector's fan speed detection circuit, it has lately started causing me problems.
A year ago, the projector refused to boot up, showing the error code 01 meaning the fans were not running. This was with the projector open and all fans spinning up to speed perfectly during the first seconds before shut down. Thumbs Down
Back then I was at a loss, as all the fan wiring and connector plugs looked good. Viewing my apparent despair, my wife started wiggling at random wires near the front of the tubes (good thing it was not running) and surprizingly it then fired up right away with NO error code. The projector then worked for a year, but recently went back into shut down mode with the same FAN error code, again with all fans running fine. This time jiggling wires didn't help... Razz
Is there any way to remove or circumvent the fan detection circuit in this projector's main board or daughter card? I have the service manual with the circuitry, but can't read those graphs for the life of me. However I can solder quite precisely if you can point me to what and where.
Understandably this is not recommended, as there will no longer be any safety system to stop the projector if it is no longer cooling properly. However, this is a risk I'm willing to take after too many hours of projector mods and little heart to do it all over again.
TIA for any suggestions, Thumbs Up
Brett
tony359
Posted: Tue Nov 27, 2007 1:00 am    Post subject:
You can "disable" the fan control bypassing it on the fans itself. You should connect the fan control wire to +12V wire so that the projector see the fan rotating all the time. You probably have a bad fan or an intermittent contact on one of the control's wire.
Ciao
A
Brett
Posted: Tue Nov 27, 2007 11:32 am    Post subject: Bad fan impedance?!?
Ciao
A
Hi Tony,
I actually did exactly that with my fan mods back in Y2K when I swapped them for Papst units. However, I hoped to disable the circuitry upstream, otherwise I will have to unsolder all the fans and resolder them, only to have to systematically replace the fans one by one until I find the culprit. A problem with this is that it took me many months to get the proper fans even with the kind help of Oliver Klohs who had the same quest for a silent 1292.
This is the extremely time consuming hassle that I hoped to avoid by strapping a circuit board or changing a resistor somewhere. Wishful thinking?!?
Cheers,
Brett
dochlywd
Posted: Tue Nov 27, 2007 12:45 pm    Post subject:
Brett,
Try messaging MP or going into his section of this forum where he talks about modding the 1292. He has done extensive research on the 1292 over the last 3 or 4 years. He's your best bet at getting the answer you are looking for.
Here's the link:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=2131.html
Good Luck!
Doc
tony359
Posted: Tue Nov 27, 2007 6:29 pm    Post subject:
Sure, I understand. With 14 fans disabling the entire circuit perhaps is better!
Let us know
Antonio
Atom
Posted: Wed Nov 28, 2007 2:44 pm    Post subject:
Hi Brett
I'm glad to see you still have the 1292. I've had other projectors but I still keep coming back to the 1292
I have had problems with the male Fan connectors on the E and DC board The fan connector body was not flush with the circuit board and when inserting or removing the plug it caused the circuit traces to eventually crack. Re soldering fixed the problem.I also re soldered all of the power transistors and other power components on the E board , that cleared up some convergence and stability problems. I think that the E board is most susceptible to the problem with cracked solder joints because of the twisting motion that it get when that whole assembly is raised and lowered to get at the CRTs.
Andrew Smile
Brett
Posted: Thu Nov 29, 2007 2:34 am    Post subject:
dochlywd wrote:
Brett,
Good Luck!
Doc
Hi Doc,
I've known Mike for quite a while and he's helped me a lot over the years. However, I think most of his efforts have concentrated on the video chain and convergence (not to mention streaking) of the 1292 versus this part of the circuitry. Given he's overloaded, I didn't want to burden him with this question because he'd probably spend an inordinate amount of time to get me out of this bind, so I hoped someone else here might have suggestions - which seems to be actually happening.
Nonetheless, thanks for your supportive reply.
Cheers,
Brett
Brett
Posted: Thu Nov 29, 2007 2:43 am    Post subject:
Atom wrote:
Hi Brett
Andrew Smile
Hi Andrew,
Nice to see ya here after all those discussions in the AVS forum!
I had an inkling that somebody else was bound to have a lead, regarding troubleshooting this shutdown. I've lifted the assembly so many times it could quite possible be the culprit, and having already entirely resoldered my former CRT direct view, I'm not shy to attack these boards. Very Happy
It would make sense as the fans are high end German Papst units, their solder joints are solid and "over soldered" and protected by shrink wrap, and their impedance is unlikely to have changed over time (I'd assume it either stays within spec since installation or never will be). Since my shut down happened twice over the past year, it makes sense that a pin connector must have come unsoldered. If so this will be one of the easiest fixes for a non tech savvy solderer such as myself. 8)
I'll keep you posted once I find a spare moment to fire up the old trusty soldering gun.
Best,
Brett Thumbs Up
cooldog
Posted: Sat Dec 01, 2007 3:35 am    Post subject:
Hey Brett ... fancy finding you here!
I'll go fetch my reading glasses (we're all gettin' on, aren't we?) and the service manual and see if I can figure out an easy mod for you.
It really shouldn't be too hard ...
Be back in a few ...
Paul
cooldog
Posted: Sat Dec 01, 2007 4:47 am    Post subject:
Brett,
Sheesh ... I'd forgotten how hellish it was working with the *copy* of a service manual that Sony sold me. Things that are supposed to be on a single fold-out page are split across several pages.
You'll need to cut a trace on the Y, or CPU board. If you have the service manual, the relevant page is 225. You'll see a signal called FAN PROT come in on pin 3a of the main connector where the Y board plugs into the motherboard. Then it goes through R59, a 300 ohm "chip resistor", then on to R123, a 10K "chip" pull-up to +5, with C63, a .01 uF cap to ground, and from there, on to pin 31 of the I/O and interrupt controller chip IC10.
Everything I see implies that the signal is actually active low, that is, if the fans stop, the signal is pulled to ground.
Simply cutting the trace somewhere between the connector pin 3a and R59, or between R59 and the R123/C63 junction should allow the R123 pull-up to keep the signal high.
Assuming you find and cut the right thing, this is safe, even if it somehow turns out to be ineffective. In that case, just patch the cut that you made and all returns to normal.
Paul
Brett
Posted: Sun Dec 02, 2007 11:46 am    Post subject: SUPER MOD TO DISABLE FAN SHUTDOWN ! ! !
Hi Paul!
Great to see you again - time sure flies?
I thought there must be a way to trick the projector into thinking that the fans are working, even if they aren't. I'll bet other folks who have hooked up their hushboxes into air conditioned cooling could unplug their fans with your suggested circuit board mod. 8)
I'll give this a try if resoldering the boards doesn't provide a quick fix. As any normally constituted 9 incher who's ever bought a replacement tube, I'd rather have this safety feature active rather than short circuited. But if for some reason the shutdown keeps active with no valid reason, then by all means I'll cut those strips as you suggest.
Thanks a million for going to the trouble to decypher those boards. With your cristal clear instructions even I can dig into the circuitry and try out the mods. Of course, if resoldering doesn't fix it, I'll cut the ribbon strips and see if the trusty old 1292 starts back up and report back to others here. Thumbs Up
All the best,
Brett
