G2 lights on BD808s
timf
Posted: Mon Nov 26, 2007 1:23 pm    Post subject: G2 lights on BD808s
Hi all,
When adjusting GS I understnad you are required to slowly adjust the G2 trimpot until the corresponding green LED just goes out, this is meant to indicates the correct Gs setting for that tube.
On my Green tube no matter which way or how slowly I turn the pot the LED remains brightly lit and wont go off, does this indicate a possible fault or something else?
Cheers.
Ile
Posted: Mon Nov 26, 2007 3:59 pm    Post subject:
Most likely trimpot for led adjustment have just drifted a bit. I have seen this is in many of those amps.
Just forgot that led and project black picture and adjust contrast to 0. Then adjust green G2 by eye to same level that blue/red are (look to lenses).
