Cracked Error Board 1292--need replacement!
Analog_Alpha
Posted: Mon Nov 26, 2007 2:42 am    Post subject: Cracked Error Board 1292--need replacement!
So, I just finished mounting my 1292. Finally! Anyways, I had noticed that I somehow cracked the error board when the PJ was upside down on the lifter. That's the very small board (orange in color), that has the two digit display for errors. Does anyone have one that they wouldn't mind sending over to Ontario for a fee?
Thank you
Chris.
Sonynut
Posted: Mon Nov 26, 2007 2:52 am    Post subject:
Sounds like a hack, yes, but you may be able to jumper the broken traces...
1272 Stack coming soon:)
Posted: Mon Nov 26, 2007 3:17 am    Post subject:
I've got a spare.
Analog_Alpha
I actually thought about that and if I can't get a replacement I'll have to do that. I hope I can find one, as I have other things to do instead of spending a day soldering. The PJ is working with the board cracked, so at least I don't have to panic for now. Very Happy
Curt you have a pm.
Thank you
Chris.
mack1
Posted: Tue Nov 27, 2007 1:42 am    Post subject:
Chris if you are having a problem I could lend you one from my spare 1292 and I live in Sarnia.What screen are you using?
Analog_Alpha
Posted: Wed Nov 28, 2007 5:27 pm    Post subject:
Thanks for the offer, but I already have one coming from Curt. The PJ works without that board, so I'm not hopeless yet.
I should of removed that board when i was tipping the PJ upside down just before it went up on the ceiling without the covers. Right now I have a temporary 86" screen, but 120" wide will be coming in within few weeks. Good to know there is another owner of 1292 in the area. I'll keep you in mind if I'm stuck again.
Thank you
Chris
