ECP-4100 Pictures jumps
gigge
Posted: Sun Nov 25, 2007 10:42 am    Post subject: ECP-4100 Pictures jumps
Hi!
I got a ECP-4100 running 720p@60Hz
Picture is great only problem is that the picture jumps.
I got it runnung from a Geforce 8500GT
DVI to VGA Adapter -> VGA RGBHV 5xBNC and HV on H inpunt - T adapter.
Using H and V is same result.
I have done restet of the unit, but still problem is not gone.
H. inhibit some times blinks red.
I have pulled out the Slot 0 card and put it back in. Problem still here..
Picture some times jump in help menu, but as often when it syncs to PC.
Can only say WOW. a great upgrade for me, went from a Barco Vision 600 to This ECP 4100
Will the Tubes from the barco unit work in the ECP ?
Best Regads Gigge
gigge
Posted: Sun Nov 25, 2007 1:07 pm    Post subject:
did some more testing.
V.MOVE make the picture jump. cant move the picture at all. H.MOVE works.
Posted: Sun Nov 25, 2007 2:12 pm    Post subject:
V move typically will not move the image very much from what I can remember. Can you try a different computer? try the SVGA output of the computer, bypassing the DVI card.
Yes, the tubes from the 600 will work in the ECP.
gigge
Posted: Sun Nov 25, 2007 3:19 pm    Post subject:
Dont know why. but it dont sync to the 15 pin VGA - 5XBNC RGBHV cable .
Only tru the DVI. found out that DVI was rgbhv signal !!!
Screen jump when nothing is connected.
Settings to auto H Hold and V Hold.
And still jumps aroumd.
:/ gonna search the forum some more..
problely something i have done wrong
cus this did not happend when i first got the unit.
Tube conditon is all good all 3 tubes 9 *happy*
Posted: Sun Nov 25, 2007 3:40 pm    Post subject:
The screen jumping with no input is normal. YOu could have a V board or RGB input board problem, but it would be rare...
gigge
Posted: Sun Nov 25, 2007 5:53 pm    Post subject:
Got it fixed !!
Pressed Source 0 1 and then recall.
Strange, i did full reset..
pressed on the card and recall.. and it did reboot..
all settings where gone.. and standard values.
Now i have to do convergence, and i like the menu..
No more trimpots for me !!
I had stange colors problem too..
It was like the there where 3 diffrerent sections..
darker on top, light in the middle and dark in the bottom.
Thanks for the replys !!
