What have I done...
chillman
Posted: Sat Nov 24, 2007 5:34 pm    Post subject: What have I done...
...I just bought a Ampro 3600 projector Shocked What do you think, good choice? Wink As there are nearly no Ampro owners in the german CRT forum (beisammen.de) I will probably bother you with some questions about these machines in the future...
Greetings from Germany!
Tillman
Posted: Sat Nov 24, 2007 5:51 pm    Post subject:
How are the tubes, does it work?
Expect to hear from Pete and Chip in 3-2-1...
chillman
Posted: Sat Nov 24, 2007 6:45 pm    Post subject:
I don't have it yet, but it should be perfectly working. Tubes are quite good for what I paid (350€+shipping), Green has some wear,but should still be useable. Blue has only very little wear, red has no wear. Really looking forward to the set! This should be quite a big step up from my sony 1030 Very Happy
Heywood Jablome
Posted: Sat Nov 24, 2007 7:05 pm    Post subject:
I've seen with mine own eyes a 3600 resolve (granted, near the center) ACTUALLY RESOLVE one-on one-off lines at 1080p48. It will be a MAJOR step up from a 1030!
Just pay attention to the Ampro experts that are sure ti chime in regarding power supply health... IIRC that was the downfall of Ampro among serious CRT HT folks.
Z-Photo
Posted: Sat Nov 24, 2007 7:58 pm    Post subject: Re: What have I done...
Tillman
My German Exchange Student thinks you are crazy. Shocked
Barco is better......
Engineer by Day
Photographer by Night
My Portfolio
Posted: Sat Nov 24, 2007 9:52 pm    Post subject:
I was waiting for Pete to chime in first as he is the resident expert. You will do well to follow his lead as children of the corn seldom lie. Razz On a more serious note, I hope you also got the factory wired remote and owners manual. The projector is useless without the remote or PC control software. An undrestanding of the "CODE" structure needs to be studied in order to gain control of the beastie. When it arrives, the first thing you should do is make sure the three fan filters and grates are removed as they plug up quick and cause overheating. There is one on the back at the power supply and two on the bottom. If they are still there, in the trash they go, never to be seen again. You will also need a special tool to adjust the lenses with. It is a 5/16 ball driver. I think a 10MM driver will work but I've not tried it. I suggest setting it up on a wheeled cart so you can experiment with screen size and projector distance. You will need the manual to explain the scan reversal procedure if it was set up for something other than table mount projection. I suggest setting it up for the first time with a easy resolution for the projector to handle like 800X600. Then as you get used to the setup of the projector move onto higher resolutions. All you need to do to get started is point it at a white wall about ten feet back, connect it to a source, turn it on and press "HELP". Focus the green tube so that you can read the menu and follow the instructions. Don't try for 960P or 1080P right off the bat. You will run into trouble. Keep the projector clean on the inside, especially the SMPS (low voltage power supply). You can pull it right out by loosening the 4 philips head screws on the sides and pull it straight up (with the power off and un-plugged). It fills with dust fast and needs to be cleaned often.
AmPro's suck!!! I'm going to buy a Barco. Anyone seen my sister? I need a date Razz
Heywood Jablome
Posted: Sat Nov 24, 2007 10:12 pm    Post subject:
I've seen your sister... You'd be safer mounting an NEC (but then, I'm fond of Asian girls!)
chillman
Posted: Sun Nov 25, 2007 12:29 pm    Post subject:
Thanks for all the advice, seems like I still have to learn a lot about ampro machines.
Wow, I didn't expect to be able to display _real_ 1080p with the set. This sounds great!
stefuel wrote:
I hope you also got the factory wired remote...
Yes, I will get the wired one with the display on it, I guess this is the right one? I know that setting this machine up won't be easy, I'm planning to use a free weekend to learn how to setup it, I will follow your advice.
I added two pics of the set.
Rated 9-7-8 by the seller, I would at least rate the green tube lower.
 Filesize:  15.07 KB
 Viewed:  5709 Time(s)
Is the cooler(?) on top of the set normal? I haven't seen this on other pics.
 Filesize:  17.66 KB
Z-Photo
Posted: Sun Nov 25, 2007 1:07 pm    Post subject:
Well - you found the right place.
Although the Ampros are not very common - the 3 people that can help you are here.
(edit > NOT ME though)
Engineer by Day
My Portfolio
Posted: Sun Nov 25, 2007 2:15 pm    Post subject:
No, that heatsink is NOT stock..Smile What is bolted to it? The convergence heatsink? Very strange...
The green tube could use replacing, but for the price it will blow the 1030 away. Good score!
chillman
Posted: Sun Nov 25, 2007 7:25 pm    Post subject:
I have no idea what the heatsink is good for, I will post here when I receive the set. I will try out how much the green tube will affect the picture when watching a movie (it will definitely be visible when displaying a white image) and then decide if I can still use it.
Posted: Sun Nov 25, 2007 10:28 pm    Post subject:
4 Mr. Green
Posted: Mon Nov 26, 2007 12:00 am    Post subject:
I can hear Pete all the way over here. He's yelling "Photo shop, photo shop. Somebody did a great job adding the tube wear effect to that projector. Everyone knows there isn't a AmPro alive that will run long enough to put that kind of wear on those tubes" Wink
Yo Pete, did I spoil your fun Laughing
Posted: Mon Nov 26, 2007 5:19 am    Post subject:
Ampro alive? What on earth are you talking about? Wink
Posted: Mon Nov 26, 2007 8:19 am    Post subject:
No it's more like the come out of hibernation from time to time and run for a bit then go back on hiatus.
