Static in the Image, Need Help
Saeid01
Posted: Sat Nov 24, 2007 1:13 am    Post subject: Static in the Image, Need Help
I have a BG1200. When looking through the lenses my blue and red crts have a bit of static is the image, which is uniform, the green shows smooth image. This is also present when I use the internal generated pattern. Any idea how I can fix this?
Saeid
Posted: Sat Nov 24, 2007 2:43 am    Post subject:
It could well be contamination in the tubes. I'd swap around the CRT sockets to make sure it's not them, and if the problems stay in the R and B tubes, then I'd suspect the tubes. I have a red here I think in good condition.
